1. Ray22's Avatar
    Join Date
    Dec 2010
    Location
    Bronx, New York
    Message Count
    1,304
    Apr 16, 2012 - Need help Mixing Shell shock for the Batmobile. #1
    Okay guys I need help I bought some Smooth On Shell Shock to use as a gel coat for the Batmobile and its says mix to 1A :4b by VOLUME Okay part A is 0.60 lbs or (0.27 kgs) and Part B is 3lbs how do I mix this crap LoL, Math wasn't my best subject.
  2. Shat happens robn1's Avatar
    Join Date
    Aug 2007
    Location
    Woodbridge, VA
    Message Count
    2,381
    Apr 16, 2012 - Re: Need help Mixing Shell shock for the Batmobile. #2
    Mixing by volume is easy, 1 part of one and four parts of the other. You need to measure the physical amount, not the weight. I use epoxy mixing cups from the hobby shop.
    I've considered using this stuff myself, I'll be looking to see how you make out with it.
  3. Ray22's Avatar
    Join Date
    Dec 2010
    Location
    Bronx, New York
    Message Count
    1,304
    Apr 17, 2012 - Re: Need help Mixing Shell shock for the Batmobile. #3
    robn1 said: View Post
    Okay Robn1 thats what I was thinkging but when I did the math on the amount of resin to catalyst they give you it looks like you would end up short so basically one would be 1 ounce and the other 4 ounces to have the right mix? I quess Lol thanks for clearing it up I will pick p those small mixing cups it will make things easier.
  4. Join Date
    Jan 2003
    Message Count
    2,781
    Apr 17, 2012 - Re: Need help Mixing Shell shock for the Batmobile. #4
    Weight has nothing to do with it.
    It's not oz. Just size. Like 1 spoon to 4 spoons. Or 1 cup to 4 cups.
  5. Ray22's Avatar
    Join Date
    Dec 2010
    Location
    Bronx, New York
    Message Count
    1,304
    Apr 17, 2012 - Re: Need help Mixing Shell shock for the Batmobile. #5
    terryr said: View Post
    Got it, you know when you over think something that's what I was doing and the brain went into shut down last night, Does not compute Lol so much on my mind trying to complete this model and getting it molded and already thinking of the next project while working on this one. Brain overload Wil Robinson I think I see smoke but thanks for clarifying things guys this is the place to come for answers.
  6. Shat happens robn1's Avatar
    Join Date
    Aug 2007
    Location
    Woodbridge, VA
    Message Count
    2,381
    Apr 17, 2012 - Re: Need help Mixing Shell shock for the Batmobile. #6
    Your math isn't working because you're comparing the weight of the two parts, not the volume. The two have different weights because their mass is different. Volume, how much space they take up, is what matters here.
    I've only been working in small amounts, but I use the Great Planes epoxy cups from Hobby Town. They have graduations in different units, ounces, drams, ccs etc. It doesn't matter which you use, just whichever gives you the amount you need. (In this case ounces probably refers to the weight of water. But that doesn't matter, you can use the markings as a volume unit.) If you need a large amount just use the whole cup, 1 cup of A and 4 cups of B.
    For my phaser build I'm using EpoxAmite laminating epoxy. It has a mix ratio by weight of 100A:29B, but by volume it's 3A:1B. Working in very small amounts made measuring by weight difficult, so I use volume (I wish all products had mix by volume directions!). I just pour out 3 drams of A and 1 dram of B.
  7. jameth1971's Avatar
    Join Date
    Jan 2010
    Location
    California
    Message Count
    1,671
    Apr 17, 2012 - Re: Need help Mixing Shell shock for the Batmobile. #7
    Can someone tell me what Shell Shock is and what it's for?
  8. Shat happens robn1's Avatar
    Join Date
    Aug 2007
    Location
    Woodbridge, VA
    Message Count
    2,381
    Apr 17, 2012 - Re: Need help Mixing Shell shock for the Batmobile. #8
    Shell Shock is a Smooth-On resin, that's thick so it can be brushed into a mold without running.
    Shell Shock® Liquid Plastic Product Information | Smooth-On
Similar Threads
  1. Bondo/filler experimental mixing problems
    Haystack Hair, Replica Movie Props
    Last Post: Dec 20, 2012, 1:22 AM
  2. Mixing color with resins/liquid plastic
    SingleSeat, General Modeling
    Last Post: Apr 20, 2011, 11:58 AM
  3. Mixing metallic powders with resin?
    Birdie, Replica Movie Props
    Last Post: Oct 3, 2009, 6:51 PM
  4. Hybrid saber mixing all 3 ROTJ Luke styles
    Mr. K, Replica Movie Props
    Last Post: Dec 21, 2008, 4:38 PM
1 2 3 4 5 6 7 8 9 10 11
