the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > PROPS, COSTUMES and MODELS > General Modeling
Landmaster help!
Discussion on Landmaster help! within the General Modeling forum, part of the PROPS, COSTUMES and MODELS category; Watched Damnation Alley yesterday and I have decided to tackle
Reply
LinkBack Thread Tools
Old 02-08-2010, 03:50 PM   #1
Smiling Demon's Avatar
Smiling Demon has not been awarded enough reputation to matter.
Landmaster help!
Watched Damnation Alley yesterday and I have decided to tackle making a Landmaster.
I need to locat some wheels and tires for it first. Once I find those they will determine how big it is going to be. I want to make it at least 1/24 scale. It may be bigger depending on what tires I can find.
Can anyone help me locate some wheels and tires?
Here is a pic for reference!
Thanks,
Kenny
Smiling Demon is offline   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 02-08-2010, 04:10 PM   #2
Treadwell has a reputation level greater than 100!Treadwell has a reputation level greater than 100!
Re: Landmaster help!
Think Tonka.
Treadwell is offline   Reply With Quote
Old 02-08-2010, 04:16 PM   #3
skiffy has not been awarded enough reputation to matter.
Great choice - this is one of my fave vehicles.
Try RC monster trucks? Could be pricey though...
skiffy is offline   Reply With Quote
Old 02-08-2010, 05:59 PM   #4
Pricey is putting it lightly. I found some that could work that are a little over sized for $40 a pair!
Tonka, let me try that!
Old 02-08-2010, 07:09 PM   #5
Just ordered some wheels and tires that I think will work out fine. They are about 1.5 inches each in diameter and they didn't cost an arm and a leg!
When they arrive I will get started on the drawing stage!
Cross your fingers!
Old 02-08-2010, 09:12 PM   #6
propsculptor's Avatar
propsculptor has not been awarded enough reputation to matter.
It's too bad the you didn't decide to build this a few years ago, the Damnation Alley Landmaster was parked off the 101 Freeway here in Hollywood since I've been here back in 1988!
I could have taken any Photo of it you may have needed, unfortunately it's been moved or sold...
I look forward to seeing your completed Landmaster.
propsculptor is offline   Reply With Quote
Old 02-08-2010, 10:12 PM   #7
division 6's Avatar
division 6 has a reputation level greater than 10!
I remember always seeing it on by way down to Disneyland every year.
This site has pix of it in it's current condition (partly restored)
D6
division 6 is offline   Reply With Quote
Old 02-09-2010, 04:18 AM   #8
I'm sorry I missed that! Would have very helpful!!
D6
Thanks for the site! It does have some pics I can use!!
Old 02-28-2010, 06:10 PM   #9
Patron Zero has not been awarded enough reputation to matter.
Smiling Demon, had you see this as yet ?
http://www.monstersinmotion.com/cart...nterior-p-8040
Patron Zero is offline   Reply With Quote
Old 02-28-2010, 08:03 PM   #10
division 6's Avatar
Most of the time that site doesn't actually have the item in stock and they are know to be recasters of many garage kits.
Also the guy listed that did the patterns never makes his models accurate.
IIRC someone on this forum was working on on a few years back, possibly Bradlyfett.
D6
Old 02-28-2010, 08:07 PM   #11
Steampunk's Avatar
Steampunk has not been awarded enough reputation to matter.
I also remember seeing it off the 101 fwy. Always wondered what movie it was from. Parked next to it was 'Princess Vespa's' Mercedes from Spaceballs.
Steampunk is offline   Reply With Quote
Old 03-01-2010, 04:17 AM   #12
Nope, didn't see that! One foot huh? Mine may turn out to be in the 1:18 - 1:20 scale!
With the wheels I was able to find it will actually turn out to be around 18" in length!
I robbed some wheels off some monster trucks I found at Walmart. The only ones I felt satisfied with the trend pattern. Working on the tri-axle assemblies right now and then the frame/chassis.
I have it mostly drawn out but it seems to change on a regular basis. Guess that's the way it goes!!
Old 03-01-2010, 04:18 PM   #13
8 perf's Avatar
8 perf has not been awarded enough reputation to matter.
As you already have your wheels, this info is redundant, but in the link above was this information.
Farm equipment tire, 38 inches in diameter and 24 inches wide, are mounted on special 16.1-inch wheels.
8 perf is offline   Reply With Quote
Old 03-02-2010, 02:10 AM   #14
yuumi2891103's Avatar
yuumi2891103 has not been awarded enough reputation to matter.
How about this TAMIYA offload tire set ?
http://www.1999.co.jp/10002386
yuumi2891103 is offline   Reply With Quote
Old 03-02-2010, 05:22 PM   #15
dakota_in_the_sky has not been awarded enough reputation to matter.
I'm thinking of casting or vacuforming a 1/24th scale kit.
If those tires are accurate, I might be able to mold and cast a set for you.
dakota_in_the_sky is offline   Reply With Quote
Old 03-04-2010, 03:56 AM   #16
Thanks guys, I have found the wheels and tires I'm gonna use. After I get over my little mishap I will get started on the wheel assembly and then the chassis!
Old 04-05-2011, 11:27 AM   #17
Should you ever produce 'working' drawings used in your build, would sincerely enjoy seeing such. Best of luck with this most excellent project !
Old 04-05-2011, 09:44 PM   #18
This project was put on the vack burner as I collected other projects. I need to get it out and finish it.
Thanks for the reminder. I will take some progress pics as I work on it.
Old 04-06-2011, 03:11 AM   #19
11B30B4's Avatar
11B30B4 has not been awarded enough reputation to matter.
I love that vehicle, it reminded me of my radio shack big trac, Damn I miss that toy...
And that movie caused me to develop a small fear of cockroaches.
11B30B4 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright © 2012 Dsteam, LLC. All rights reserved.
1 2 3 4 5 6 7 8
