hello all, new guy here...
I finally talked my wife into letting me buy a fine molds 1:72 Millenium Falcon, then the photoetched fan grilles and landing gear baffles, paint, sheet polystyrene...on and on...
I made up an IR remote switch that turns on with any button from a TV remote, it included a pair of flasher circuits but turned out to be too large to fit inside the MF hull so I pared off the flashers and just went with a remote controlled LED switch. I will route the light from the LEDs with fiber optic strands. The board also supports the inverter for some EL tape. The whole thing will be powered by 10 NiMH AAA cells.
I like the way the switch works but I didn't like the form, so I used the PCB drawing tool and custom fit the PCB to the hull...
then etched up another PCB that I will cut out at work tomorrow and populate. I will post some pictures of the finished board...
the smaller board in the picture is the flasher circuit that will be much easier to mount inside the hull. It measures 1.2" x 1.8" and will be powered from the IR board.
