the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > MODELS > General Modeling
I need help with OBJ Metal Gear
Discussion on I need help with OBJ Metal Gear within the General Modeling forum, part of the MODELS category; I am able to rip the mechs and other items
Reply
LinkBack Thread Tools
Old 11-27-2011, 11:03 PM   #1
akiba1953's Avatar
akiba1953 has not been awarded enough reputation to matter.
I am able to rip the mechs and other items form Metal Gear Peace walker from the PSP. But when I edit them in 3ds max I dont know how to simplify them. There are a ton of internal parts and parts that over lap that still show up in the pepakura program.
akiba1953 is offline   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 11-27-2011, 11:39 PM   #2
akiba1953's Avatar
Re: I need help with OBJ Metal Gear
In Short, I need someone that is able to edit the files to be used in pepakura. I can rip and clean up. But cant edit the overlapping items. I wind up with free floating items in pepakura.
Old 11-28-2011, 03:44 PM   #3
Captain April's Avatar
Captain April has not been awarded enough reputation to matter.
If you built the model in 3d max you can freeze the parts you want to keep and delete everything else. It may not be possible because if the model imported as a single object then you are out of luck doing it easly. You can still go in and delete points, it will take longer and you have to be carefull not to delete points you want to keep.
Captain April is offline   Reply With Quote
Old 11-28-2011, 05:12 PM   #4
Fett_Ish has not been awarded enough reputation to matter.
Right click on the object and choose convert to editable poly. With the object selected go to the modify panel (little bent cylinder icon). At the top of the menu there are icons for vertices,edges,borders,faces,and elements. Choosing the last one will allow you to more easily select parts of the mesh that do not share vertices. Simply choose what you want to keep,invert selection (ctrl-i or edit/select invert from the menu) and delete, or choose what you don't want and delete. Hope that helps.
Fett_Ish is offline   Reply With Quote
Old 11-28-2011, 05:22 PM   #5
akiba1953's Avatar
Thanks that will help with the smaller Items. But they are all rips from the game. the Mech's have tons of parts. Im looking for someone to help with the clean up before release. I might be making it sound harder than it is lol.
Old 11-28-2011, 07:54 PM   #6
akiba1953's Avatar
OK i found some tutorials on BOOLEAN and attaching. working. more work than i wanted but cant really complain
Old 11-28-2011, 08:03 PM   #7
Landstalker has not been awarded enough reputation to matter.
What number is Max up to now?
Landstalker is offline   Reply With Quote
Old 12-04-2011, 11:10 AM   #8
SurlyBird has not been awarded enough reputation to matter.
Autodesk uses an annual release system now. Most current version is 3DSMax 2012, I believe.
SurlyBird is offline   Reply With Quote
Old 12-09-2011, 09:24 AM   #9
Lukea's Avatar
Lukea has not been awarded enough reputation to matter.
I am not clear on what you need but I have been doing this professionally for years. Send me the model with more info and maybe I can help.
Lukea is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Metal gear model kits? Wes R General Modeling 23 04-17-2012 04:27 AM
Metal Gear Solid Movie vetteboy1982 Entertainment and Movie Forum 18 01-02-2012 04:14 PM
Metal Gear Solid 4 : Stun Knife longineus Replica Movie Props 6 01-14-2011 07:52 PM
Metal Gear Solid Costumes Darth Alias Replica Movie Costumes 50 04-19-2008 07:22 AM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
