Page 8 of 15 FirstFirst ... 345678910111213 ... LastLast
  1. Join Date
    Nov 2001
    Location
    Langhorne, PA - just outside of Philadelphia
    Message Count
    1,683
    Aug 30, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #176
    I have been thining the same thing for some time... its cool but it seems you actually could have saved a lot of time by building it yourself
    I'm still looking forward to seeing it completed.
    Jedi Dade
  2. blakeh1's Avatar
    Join Date
    Apr 2011
    Location
    Warminster, Pennsylvania
    Message Count
    268
    Aug 30, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #177
    Yeah, I wonder how much of the original will be left, or at the very least, not severly altered...
    This is shaping up to be a real work of art. Excellent!
  3. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Sep 4, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #178
    I thought so myself, that it would be easier to use the Hasbro hull as a jumpstarter At least I've gone over that hurdle of building the dome and learned quite a few lessons in the process about what you can and can't do with the Hasbro. Anyway, I'm at the point I would've found myself in had I built the hull in styrene. I'll just make believe that's exactly what I did.
    It's just not the 5-footer without the Koolshade and the cooling fans - always wondered how my crude guitar-string koolshade would lend itself to looking the part. So I grit my teeth and kept myself glued to my seat until I finished one - I've never been more surprised about my willpower. These exhausts should look good enough once cut down to proper height:
    By the way, I would be so happy if anyone can tell me what the real fans on the 5-footer were. And it's so hard to make out from the photos whether the fan tops were domed or not. (Photo by Frank Wire/ studioscale.com):
    I finally bit the bullet and bought some Alumilite to try my hand at casting - the little actuator leaves me no choice but to learn how because I doubt if I can scratchbuild the 52 pieces of these that I need and still keep my sanity and my eye vision.
  4. superjedi's Avatar
    Join Date
    May 2003
    Location
    Newport News, VA
    Message Count
    2,063
    Sep 4, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #179
    Guitar strings? That's what I call committing to the project!
    Or maybe you should just be committed.
    That vent came out great! Look forward to seeing how your casting efforts come out. That's one thing I wish I had been able to do with my scratchbuild years ago.
  5. cayman shen's Avatar
    Join Date
    May 2005
    Location
    New Hampshire, USA
    Message Count
    3,970
    Sep 4, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #180
    I'm sorry, you MADE the mesh out of guitar strings?! Am I understanding that correctly? And that people, is why I will never make a good scratchbuilt model. That kind of patience is an alien planet to me!
  6. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Sep 4, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #181
    Hey John, thanks. Yes, electric guitar strings. I used 0.23mm gauge. Eric, I'm surprised at how well the alumilite casting turned out. And dries hard quickly too - 7min as mentioned in the instructions but I pried it out at 10min. My very first cast (yipee!).
    Scratchbuilding that first actuator took me more than 2 hours - rolling the two-part putty, spacing the ribs and gluing wrong, retrying, etc. Originally thought about building the 52 actuators by hand. Just imagine how imperfect each one is going to be in its own way so this alumilite's gonna be a real timesaver. As soon as I cast 5 pieces I'll probably make a new mold of 5 in a row.
    Right now I'm just marvelling at how well the resin took the shape of the mold like magic. To the resin oldtimers, excuse my excitement but it's a Eureka moment for me.
  7. Join Date
    Jul 2011
    Message Count
    37
    Sep 5, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #182
    wow! i look at all the pages and stunned how much work has gone into this and how such simple things like part of a model motor was used to make the falcon.
  8. superjedi's Avatar
    Join Date
    May 2003
    Location
    Newport News, VA
    Message Count
    2,063
    Sep 5, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #183
    Joseph, that molded part came out great!
    Like you say, once you get a few done, making a gang mold will save even more time.
  9. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Sep 5, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #184
    Thanks, guys! Cut up some mandibles today:
    Strange thing about that 5-footer top-view photo: The left-side mandible
    maintenance wells are a bit higher than the ones on the right. I wonder
    if it's the photo that's distorted or the actual model was like that? Anyway,
    patterned the holes after the right side one.
    I know it's going to be a tough job to scratchbuild the details, but as long as I've got the basic shape of this starship done, I'll do that slowly, adding a few details at a time. I have to learn a few techniques from squbiedoo and superjedi.
  10. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Sep 6, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #185
    The maintenance wells don't seem level. Could it be due to distortion in the photo? Even those boxes attaching to the hull look off. The top of the mandibles look level, though.
  11. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Sep 6, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #186
    Patched bottom (front landing gear boxes). Need to correct the shapes of the maintenance wells too, which are different for port and starboard on the ANH 5-foot Falcon.
  12. Vandark's Avatar
    Join Date
    Apr 2005
    Location
    U.K.
    Message Count
    244
    Sep 7, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #187
    Wouldn't it have been easier scratch building this?
  13. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Sep 7, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #188
    Vandark said: View Post
    Hi Vandark. Yeah if I were to do a second one I'll definitely take the pizza slice bulkeads route to scratchbuild the hull. My son is watching me, though, with crossed arms and a scowl on his face to keep to my promise after tearing his toy apart.
  14. tek2graphics's Avatar
    Join Date
    Apr 2010
    Location
    Fort Smith, AR
    Message Count
    534
    Sep 7, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #189
    LOL
    What a dad would do for his boy!
    That's wonderful!
    crackerjazz said: View Post
  15. Weezer's Avatar
    Join Date
    Jun 2008
    Location
    Canada
    Message Count
    227
    Sep 7, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #190
    You are crazy... keep up the great work Crackerjazz.
  16. Vandark's Avatar
    Join Date
    Apr 2005
    Location
    U.K.
    Message Count
    244
    Sep 7, 2011 - #191
    It's awesome work! I've been following since you started and it's gonna look great when it's done.
    I've got an idea! You could use all the parts you take from it and scratch build all the missing parts to re-construct the toy version!
  17. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Sep 8, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #192
    Thanks, guys! Hi Vandark, thanks...I'll try
    I take that back.....looks like the port and starboard front landing gear openings are the same on the ANH 3-gear version. It's the colors/weathering and plating arrangement around them that makes the other one odd-shaped. I wanted to build that version but couldn't find too many photos of the underside, haha. .....
  18. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Sep 17, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #193
    I thought this was the fun part. Crazy plating.
    My first plate had too large notches.
    Measured better and made a template for the rest of the notches.
    Many a time the glue would grab and I couldn't reposition the plate. Not too happy but i couldn't start over - plating is too laborious. Tried removing these plates but they are clinging on so well - and when I tried to pry one off with the knife the plate gets bent out of shape and a portion of it just won't let go; the plate then has to be ripped out and what's left sanded off - making the surface too uneven for replating. So I'll just leave these on. But I'll try to devise a better way to achieve the tighter and more even spacing they require.
  19. Formerly Reckless Pilot Junk Pilot's Avatar
    Join Date
    Apr 2005
    Location
    Sydney Australia
    Message Count
    548
    Sep 17, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #194
    Looking great, crackerjazz. Hope we see more updates very soon.
  20. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Oct 12, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #195
    Slogging on....I'll get there yet.
    Primed the "koolshade" to see what it will eventually look like:
    The .05mm styrene I used to patch the bottom was showing the ribs liked the stretched skin of a WWII biplane. I should have used 1mm. Really love that original curved belly of the ANH Falcon sans the front landing gear boxes - I'm gonna get there yet....
    Puttied up, bondoed and sanded smooth:
    Tried making the front panel with bits of styrene using ozzy's and stevestarkiller's panels as references. Maybe I'll eventually just end up printing them out like decals but wanted to see how far my patience will take me cutting and gluing styrene details before I finally give up.
  21. Formerly Reckless Pilot Junk Pilot's Avatar
    Join Date
    Apr 2005
    Location
    Sydney Australia
    Message Count
    548
    Oct 12, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #196
    Awesome. An update.
    Will you be doing the plating overhang where the mandibles meet the saucer as well?
  22. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    896
    Oct 12, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #197
    Hi JunkPilot, yes that's exactly what I'm planning to do. I've sanded off all the plating from the Hasbro and will be cutting off all overhang to re-plate the whole thing as the plating patterns are different on the bigger model. And I've always wanted to see if I could copy the dilapidated overhangs on the 5-footer. Hmm, wonder if they were that way in ANH or was that done by the movers?
    Forbidden Plastic photo:
  23. Join Date
    Nov 2006
    Message Count
    433
    Oct 13, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #198
    Keep at it mate,
    Ozzy
  24. Formerly Reckless Pilot Junk Pilot's Avatar
    Join Date
    Apr 2005
    Location
    Sydney Australia
    Message Count
    548
    Oct 13, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #199
    Look what I now have. I had to hand over $20 to my nephew for it but I'm wondering who really got stiffed! lol
    The thing that surprised me was the SIZE. I measured it out and it's damn near studio scale with the 32in Falcon, and even though all of the detail is based on the 32in, it makes wanting to convert it to a replica 5ft'er even more daunting.
    Crackerjazz, if you pull this one off you'll be a GOD in my eyes.
    Last edited by Junk Pilot; Oct 13, 2011 at 7:02 PM. Reason: Wrote something better
  25. superjedi's Avatar
    Join Date
    May 2003
    Location
    Newport News, VA
    Message Count
    2,063
    Oct 13, 2011 - Re: Hasbro Legacy Millennium Falcon Conversion #200
    Joseph, you have to do the damage! That's what gives the Falcon her character.
    One of my favorite damage sections:
Similar Threads
  1. Hasbro AT-AT conversion?
    TazMan2000, General Modeling
    Last Post: Oct 14, 2012, 9:05 AM
  2. Hasbro AT-ST toy conversion
    REL, General Modeling
    Last Post: Aug 14, 2012, 9:46 AM
  3. Millennium Falcon reference of names on the 32 falcon
    propcollector, Studio Scale Models
    Last Post: Sep 25, 2011, 7:50 AM
1 2 3 4 5 6 7 8 9 10 11
