If you need a donor kenner falcon for parts let me know. After this is done I hope you tackle the new AT-AT
Oh, the old cockpit fits... Thats cool!
Mods looking good!
Pretty interesting concept..... I'll be watching this.
Fantastic work so far! Can't wait to see more!
Rich
Cut the cockpit tunnel:
Fixed the detachable panels in place with some gorilla glue. The glue expands
so I'll need to chisel the excess away:
The donor cockpit:
On the left is the donor cockpit. On the right is the Legacy Hasbro's
that I've cut off. Notice how big it is.
Another beauty about the older toy cockpit is that it looks better, porportionally.
What a great conversion so far! Are you planning on having it lighted as well? Also, are you going to have it based in a landing position or will it be flying? I look forward to seeing the finished model!
Not much done, except fixing the detachable panels in place. The upper crab-shell's taking shape.
Rectenna dish area will need to be redone. It's oversized on the toy.
I can't quite put my finger as to why but that's true - it does look better proportionally. And it's got more of that B-25 bomber cockpit feel that, I read somewhere, influenced the Falcon's cockpit design. It "moves" while staying put, while that bigger cockpit is just like a stationary slab, for some reason or another.
The size does beg for lighting. I never intended to at first and I'm still debating. But I've seen some highly-detailed lit-up FM cockpits here on RPF and the Finemold's half the size of this Hasbro. The 5-footer's cockpit wasn't that detailed at all, though - a couple of seats, and what look like round gauges in the back, a bare control panel and a couple of real LEDs sticking out by their leads. So I'm torn between going for that prop look or detailing the cockpit.
In-flight is what I had mind. The Falcon looks "fast and dangerous" that way. It takes up too much space on a desk so, as suggested by my kid, it'll be suspended from the ceiling along with similar- scale 1/48 X-wings flying on either side zooming away from an exploding Death Star. The Death Star's taking it too far, of course - 5-year-olds and their wild imagination. Why do I find myself riding along? The model's going to be way lighter. The toy was 15 pounds originally and has now shed a ton after de-gutting.
Another option for thde ockpit might be to contact Frank Cerney... Brudlefly. At one time he was making castings of the 32 inch cockpit for scratchbilders... He was going to take a break from the hobby a bit ago but its worth a PMIt "should" be close scale wise.
Jedi Dade
Now that is one sweet build! The work that you're throwing into this is just crazy! Have you crunched the numbers and determined the scale..... maybe 1/48?
Going by Wikipedia which gives length and width as 34.75 (111.2 ft) and 25.61m (81.95 ft), respectively, then this Hasbro mod (with mandibles cut to proper length) is 1:45th scale.
The 5-footer prop, interestingly, is 173cm (around 68.11 inches) as mentioned in Chronicles p. 95, which puts it at 1/20th scale based on Wikipedia dimensions.
Some sources, Chronicles included, give the full-size length of the fictional ship at 27m (86.4 ft), which puts this Hasbro mod at approx 1:35 scale and the 5-footer at approx 1:16 scale.
I faintly recall the full-size prop built in England being longer than just 86.4 feet, though. I thought I read it was over a hundred feet long. But they could have built the prop according to blueprints of invented dimensions, as long as the proportions were right and as long as it looked huge on-screen. Some people say it's an imaginary ship - all dimensions were imaginary and only the proportions count. I would think so, too. But who knows, the original designer might have really cared enough to scale it up with the other ships and the people riding them and a definitive source exists, perhaps hidden in a forgotten ILM vault somewhere.
How's working on this type of plastic? Is it pretty close to "model grade" styrene? Or softer?
I noticed you're working with what looks like a really fine jeweler's saw and wondered how easy/difficult it is to cut and clean up.
I did a couple of SW toy mods years ago and remember the plastic being pretty difficult to sand smooth because of its softness. It was a pain!
Great work. I can't imagine the time you've dedicated to this, but well worth it.
Hi Eric! (guys! Eric's the one who built that amazing 32-inch "5-footer!") It's hard plastic of a different grade on the Legacy Hasbro falcon, I guess - less brittle than polystyrene. Using the usual polystyrene cement is less effective than using loctite superglue gel which sticks like hell to this kind of plastic (I should've found that out earlier than experiementing with gorilla glue first - which expands and needs grinding the excess off).
Use the gel to stick styrene to this plastic, too.
There are parts which are the "rubbery" plastic kind but they are the ones that you don't need on the conversion - such as the sidewall detail and the corridors. All the rubbery plastic parts are detachable and are for discarding. Everything else I haven't found any difficulty sanding smooth, cutting and cleaning up so far.
The saw I'm using (for curved shapes) is Weeks' 360-degree spiral-tooth saw, the best thing on earth for curves than flat-blade saws. It's thin and has spiral blades (which go around it - think candy cane - instead of teeth) It cuts sideways in any direction you go. And it won't cut your skin. It's my "manual" laser cutter : ) I use it for curves only, though. I still use my trusty regular hacksaw blade for straight lines.
[QUOTE=Jedi Dade;1386313]Another option for thde ockpit might be to contact Frank Cerney... Brudlefly. At one time he was making castings of the 32 inch cockpit for scratchbilders... He was going to take a break from the hobby a bit ago but its worth a PMIt "should" be close scale wise.
Thanks for the suggestion, Jedi Dade
Spiral toothed saw. . . interesting.![]()
Yeah, the more rubbery plastic is what I was talking about. It was a bear to work with.
[QUOTE=crackerjazz;1367902]
/QUOTE]
how on earth did you get your pic to line up with the reference photo so perfectly?
great thread btw...
Bad luck takes a holiday. $20 at a garage sale today.
Wow, nice! Now, we can share ideas on how to go about it. I'm sure you're having second thoughts - "Do I preserve, or do I convert?" I had sleepless nights just thinking about itMy son was struck the hardest. He was shocked to see me one morning over the Falcon which was all in pieces on the floor. I was holding up the screwdriver grinning sheepishly. At that moment he was the dad I was the kid. It took him a while to resign and accept but now he's quite excited about how it turns out.
I say go for it especially since it is being released again.
Hey, Amish Trooper, I didn't know that : ) That's good news - where'd you learn about it?
Here you go bud.
http://www.therpf.com/f12/legacy-col...shelves-97194/
