1. Join Date
    Sep 2011
    Location
    west australia
    Message Count
    104
    Aug 19, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #326
    that cockpit looks great.will use this as reference and inspiration when i get to the cockpit on mine.should be making a start in a few weeks on my hasbro conversion, i hope.gotta finish other projects first.
  2. Rodmart85's Avatar
    Join Date
    Jul 2010
    Message Count
    189
    Aug 19, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #327
    Thanks guys,
    thanks Junk Pilot.
    Here is an idea. If you see the pics I posted of my conversion you will see I constructed an styrene structure to support all that it is left after we start "slaughtering" that poor toy, jajajajaja.
    Well, at first I decided to use the Legacy mandibles and tilt them to the angle the mandibles are on the 5 footer, one of the more important differences for me with the ESB Falcon that has parallel mandibles.
    Even with this arrengement they looked bad, they are to big, so I decided to design a new support structure for the Legacy hulls that include the mandibles at the right proportion between the Hasbro disc and the 5 footer disc and mandibles.
    I hope I am making myself clear, is kind of hard to explain. Anyway here is the blueprint of the structure I am talking about.
    The red circle is the Hasbro's hull size. As you can compare with the 5 Footer pic translucent behind I've scaled the mandibles to match the proportions of the 5 Footer with the Legacy hull.
    I also give you the height of the side walls and mandibles that I scaled down to 1/53 scale. I've been studying the 5 footer with Gort, Stu, and all the cool guys on the 5 footer thread for months so I believe this measures could be very close to the original prop.
    If any one wants this structure blueprint at a higher reso to print write me to hikaru84@gmail.com and I'll mail it.
    bests:
    Rod
  3. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    894
    Aug 19, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #328
    Hi Rod, how do you manage to create all those details? Superb job on that cockpit!
  4. kokkari's Avatar
    Join Date
    Aug 2012
    Message Count
    18
    Sep 9, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #329
    So I think that I can tell that you used the guitar strings for the vertical lines of the koolshade, but what did you use as the tiny horizontal ones on the cockpit vents?
  5. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    894
    Sep 9, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #330
    Hi kokkari, I used the same thin guitar strings It was a little hard on the eyes gluing on those tiny hair-like pieces. A magnifying lens and a good pair of side cutters helped a lot along with the tweezers. Someday I 'll get back to building mine. I got stuck at the armour-plating stage. I kept thinking how the plating should be cut from pieces of a vacu-formed hull to conform well to the dome.
  6. MonsieurTox's Avatar
    Join Date
    Jun 2006
    Location
    Paris, France
    Message Count
    3,220
    Sep 10, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #331
    Rodmart85 said: View Post
    Rod,
    That's not true, TESB Falcon's mandibles toe in.
  7. Join Date
    Aug 2007
    Message Count
    42
    Sep 10, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #332
    M. Tox is correct. The “32 incher’s” mandibles DO toe in. Fine Molds got it wrong with their kit.
    Mark
  8. Join Date
    May 2010
    Message Count
    289
    Sep 10, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #333
    Darth Humorous said: View Post
    Mark
    the only representation of the falcon (other than toys) that doesn't toe in is the 1/72 fm mf. Even the 1/144 fm mf has a wee bit of toe in
  9. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    894
    Sep 15, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #334
    Finally got the Hasbro size print! AMT size on right. These ship out to Rodmart for correcting
    and finishing and, hopefully, get myself back to building the half-size Falcon.
  10. Join Date
    Nov 2006
    Message Count
    433
    Sep 15, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #335
    crackerjazz said: View Post
    What do you mean correcting? is there somthing wrong with them?
    Ozzy
  11. RPF Premium Member jedimaster's Avatar
    Join Date
    Nov 2009
    Location
    Planet Perth
    Message Count
    2,678
    Sep 15, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #336
    Baby Wankels..... Cute.
  12. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    894
    Sep 15, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #337
    Cute babies, aren't they : ) Just need to put those ridges, correct the shape of the curve a little
    and round the tip a wee bit. All in all, though, they're a chip off the old engine block.
  13. Formerly Reckless Pilot Junk Pilot's Avatar
    Join Date
    Apr 2005
    Location
    Sydney Australia
    Message Count
    548
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #338
    That's awesome, CJ.
    My own conversion, as well as everythign else, is on hold for a while as my wife and I prepare for our new baby in Nov/Dec, and at the same time work on the house as we get ready to move out then rent it out. So basically lots happening and no time to do it in.
    Last edited by Junk Pilot; Sep 16, 2012 at 2:15 AM. Reason: Can't put a swear word in, no matter how I tried to write it.
  14. RPF Premium Member jedimaster's Avatar
    Join Date
    Nov 2009
    Location
    Planet Perth
    Message Count
    2,678
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #339
    Junk Pilot said: View Post
    That's awesome, CJ.
    What's the due date Dean?
  15. Formerly Reckless Pilot Junk Pilot's Avatar
    Join Date
    Apr 2005
    Location
    Sydney Australia
    Message Count
    548
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #340
    The full term date is 10 Dec but we know he'll (yes it's a boy) be coming before then and I can see it now he's gonna wanna play with "daddy's toys".
  16. RPF Premium Member jedimaster's Avatar
    Join Date
    Nov 2009
    Location
    Planet Perth
    Message Count
    2,678
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #341
    My 3rd boy is being delivered on the 7th by c section so I know exactly when I gotta stop working on my models..... Ahh deadlines... Gotta love em.
  17. Formerly Reckless Pilot Junk Pilot's Avatar
    Join Date
    Apr 2005
    Location
    Sydney Australia
    Message Count
    548
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #342
    Dec 7th? Wow, they may be sharing the same birthday. Do you have any names picked out yet?
  18. RPF Premium Member jedimaster's Avatar
    Join Date
    Nov 2009
    Location
    Planet Perth
    Message Count
    2,678
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #343
    From that day forth he shall be known as Jude...... The Dude. Coulda said Han Solo to be on topic but I can't lie. Sorry for the HiJack CJ ... Back to your usual programming. You?
  19. Formerly Reckless Pilot Junk Pilot's Avatar
    Join Date
    Apr 2005
    Location
    Sydney Australia
    Message Count
    548
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #344
    We both have 3 kids from previous marriages so this is our first together and her youngest is 21yo but mine is only 14. It kinda sounds like the Brady Bunch but unfortunately I don't see my kids.
    As far as names go we haven't chosen anything as yet but we do like Lachlan, Jacob and Caleb. I guess we'll know which one he is when we see him.
    Sorry CJ. Over to you Red Leader.
  20. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    894
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #345
    Not at all, fellas. My pleasure to have you around. I am envious - it's the Year of the Dragon and a child born in this year is lucky. You're both lucky. As for me - just one boy turning eight at the end of the year. Come to think of it - he was five when I started the thread.
  21. RPF Premium Member jedimaster's Avatar
    Join Date
    Nov 2009
    Location
    Planet Perth
    Message Count
    2,678
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #346
    He'll be fifteen when you finish it....
  22. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    894
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #347
    That early? No way. I'll let him finish it in his lifetime. Or he could pass it on to his son to finish. That's why they call it a Legacy Falcon.
  23. RPF Premium Member jedimaster's Avatar
    Join Date
    Nov 2009
    Location
    Planet Perth
    Message Count
    2,678
    Sep 16, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #348
    Ha.. Nice one ...... "grandpa.... What's a millennium falcon?"
  24. Formerly Reckless Pilot Junk Pilot's Avatar
    Join Date
    Apr 2005
    Location
    Sydney Australia
    Message Count
    548
    Sep 17, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #349
    "Well, back when I was your age toys were MEANT to be played with."
  25. Join Date
    Jun 2010
    Location
    Toronto
    Message Count
    894
    Dec 8, 2012 - Re: Hasbro Legacy Millennium Falcon Conversion #350
    I think I'm ready to draw my own 3D parts for printing. Printing is here to stay so I might as
    well join in. I'll start with the easy ones first and see what I can accomplish.
Similar Threads
  1. Hasbro AT-AT conversion?
    TazMan2000, General Modeling
    Last Post: Oct 14, 2012, 9:05 AM
  2. Hasbro AT-ST toy conversion
    REL, General Modeling
    Last Post: Aug 14, 2012, 9:46 AM
  3. Millennium Falcon reference of names on the 32 falcon
    propcollector, Studio Scale Models
    Last Post: Sep 25, 2011, 7:50 AM
1 2 3 4 5 6 7 8 9 10 11
