Replica Props |
Screen Used Props |
Replica Costumes |
Sculpture and Makeup |
General Modeling |
Studio Scale Models |
Movie Discussion |
| Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models. |
Discussion on First Ever Official RPF Group Build - IT HAS BEGUN... within the General Modeling forum, part of the MODELS category; OK question time: The panel lines on black surfaces... are
LinkBack | Thread Tools |
#151 |
Re: First Ever Official RPF Group Build - IT HAS BEGUN...
OK question time: The panel lines on black surfaces... are you hand brushing white? Light grey? Something else?
I see the technique where you paint them black before full paint, and they'll show subtly through, but you can't do that with black. Also, for mine, should I stick to hand painting the black, or get some cheap flat black in a rattle can and spray it? (Remember its itty bitty, 1/72) Here are some before/after pics. Its defiantly fixable, but we busted it Sat. night, and had to have to completely done by 7am Sun. morning, and we didn't pack any extra parts. So we couldn't fix the landing gear w/o some stuff from the hobby store that wasn't open on Sunday. It will fly for real though! |
RPF Sponsors
#152 |
That's definitely an interesting design - certainly one I wouldn't have imagined. How was the stability of the flow over the airfoil? Do you guys get to run computer sims or at least get some time in a wind tunnel? I'd be interested in see how the concave sections of the leading edge scallops affected air flow.
Anyway, back to modeling. The panel line wash is done with a product called Pro-Modeller wash. It comes in light and dark, for obvious reasons . You need, at least, a satin finish for it to work (but gloss is better). Brush it on, let it dry overnight and wipe off with a damp paper towel. If it worked correctly, it will have stayed behind in the panel lines.The problem with black is that you can't pre-shade. If you're really ambitious, you can post-shade by taking your base coat, adding a few drops of white to lighten it up and spraying the center of each panel. You might be better off, making a shade of dark grey, brushing it on a few select panels, masking over them when they're dry and then painting the top coat. When that's dry, remove the mask and you'll at least get some panel variation. It's hard to see on mine, but subtlety is the point. You want to make it look like they may have replaced a panel, not purposely re-painted one. Even in 1/72, you'll get a much better finish by using something in a rattle can. Find the lightest shade of primer you can (white, if you can find it) and then mist on coats of black. To make scale black look correct, it needs to be lightened up a bit. Somehow, I managed to pull it off without lightening the color any. Call it a serious stroke of luck .-Fred Last edited by Gigatron; 04-20-2010 at 12:01 PM. |
#153 |
We didn't do any CFD, but we did do wind tunnel tests, and our stall angle increased about 7* (IIRC, I wasn't on that part of the project). I'll probably start a thread about it once I get all my pics and video uploaded, and explain it more, but its one of those things that works at low Re, so for RC its fine, but probably not for a full-size plane. It works for these guys though:
![]() So sweet, looks like I can use my favorite paint (the $1 flat black from Lowe's), but I'll take a look at that Pro-Modeller stuff... I've used that method on stuff before |
#154 |
Here's the pics I took at the museum:
http://www.flickr.com/photos/lizardj...7623918873806/ May or not be helpful. Theres some SR-71, replica X-1, parts from the X-15, bunch of spacesuits, and the Apollo 13 capsule! (along with other stuff) |
#155 |
Thanks for those pics, Liz. Even if they help only one person, they're useful
.And in my own modeling news, here's my X-1 in progress. Sorry I didn't take more WIP pictures, but it kind of just fell together before I knew what was happening. Overall ![]() Cockpit ![]() Cockpit again ![]() This is mostly an OOB build. I fixed the front oleo so it looked like something more than a lump of plastic. I also built a styrene box that sits between the cockpit and wheelwell. I filled it with pennies and superglued them in place. Otherwise, she'd be an ass-dragger, unless I used the stupid clear rod. Now I need to decide on a final color for it... -Fred |
#156 |
Is it molded in orange, or did you put a base coat on?
#157 |
#158 |
That orange actually looks pretty close!
Man, Fred - you'd have a field day with the larger 1:18 cockpit! |
#159 | |
Quote:
Too bad every single piece was molded in this orange. Plus the top and bottom seams meant a lot of sanding. And when it's a revell kit, that means raised detail, which goes bye-bye during the sanding process .I've since rescribed the obliterated detail and added masking tape seat belts (really hated the painted on delaies) and wiring to the backside of the IP. I'll take new pics before I attach the canopy (which took an hour to mask )I would have loved to work on a pit that large. Just too bad I'd have no place to display the thing. So, Rob, thinking of doing any other builds for this GB? There are a lot of 1/72 X planes that would fit the build requirements, go together really easily and make for an interesting display. -Fred |
#160 | |
Quote:
So that I don't go mad masking off tons of squares, I was thinking I'd mask all the horizontal lines first, then do all the verticals second (using terms "horizontal" and "vertical" loosely). |
#161 |
Man Fred, you build quick! That X-15 is MOST Impressive! I'm still stuck with my Moonraker build, slogging away at it. There is light at the end of the tunnel though, so hopefully I'll be getting to my GB entry soon.
As for the Revell kit being done in orange, at the time they were trying to strike a happy medium between selling kits to adults and kids (when more kids built models anyway). That is the reason for the day glo orange as their thinking was a kid wouldn't have to paint much if they still wanted an orange ship (adults with more skills could paint away of course). The kit is not bad either as I picked one up recently to give me ideas for my Pegasus 1/18 model. So Fred, I take it you are starting a 1/144 shuttle here pretty soon?
#162 |
Well I finally got some work done on mine yesterday...
![]() I do see what you mean about refrence vs. kit directions though... 1) Where does Revell get the idea that the engine of this thing should be Gunmetal? I'll probably just stick a coat of Al on there... 2) So for the fuel tanks (of which its really hard to find pictures), it says to paint the front part a Bright Al, and the rest a Flat Al. But when I was in class today, flipping though one of my textbooks, I came across a pic of the 66671 with fuel tanks (!), and the shiny parts are in back with the sandblasted parts in front. What the deuce!? 3) This kit comes with 2 sets of accessories, one to do the Black version, and one to do a later White version. This includes decals and a SCRAMJET, but it also means the canopy is set up for the White version (with the Port window sealed). Yeah, I could cut it out, but there is no extra clear window piece, and I can't find proof either way if the Black 66671 ever had that window sealed. Gyyah... So basically what I've figured out is that I need to do 3 of these... One in Flight mode in Black, one in White and one Ground Black (without fuel tanks). Though I don't know about the fuel tanks now... I was going to do them, but most of the pics I'm finding are without them, plus when I filled the seam, my sanding tore apart the panel lines. (I need to pick up some 500-600 grit sandpaper... oops) |
#163 |
Rob, on the pegasus kits, are the canopy frames raised? They're raised on the revel kit and what I did, ever so slowly, was to take a 1/2" wide strip of tamiya masking tape and burnish it down overa section of the canopy. Then used a new #11 blade and beveled it into the corner between the frame and the glass and ran it along the edge. The hardest part is making sure your corners meet, so that when you pull the tape off the frame, the tape stays on the window. Otherwise, you end up remasking individual panes of glass - go ahead and ask me how I know
. I had to do that 3 times to get full coverage. Even using 3/4" tape would have taken 2 passes and it probably wouldn't have turned out as well (and "turned out as well" is a very relative term, ). I'll post a pic tomorrow of the masked canopy before painting. And of the new details in the pit.Thank you, Jay. I can't fathom why I'm building as quickly as I am for this GB. I usually go a lot slower. But I'm definitely looking forward to the lifting body collection. I can see placating kids with the already orange finish, but any adult modeler is going to have to repaint the exterior anyway, once they're done cleaning up all the seams. Just wish the orange wasn't so hard to cover. I lost a lot of detail just trying to hide that dang orange color in the pit. One orange sprue and one neutral grey sprue would improve this kit 10 fold. And yes, you guessed it, there will be a full 1/144 stack to finish off this group build. A bottle of international ornage is all that stands between me and the beginning of that monster. Liz, be prepared to be confused. I do have proof that good ol' 71 did wear that eyepatch on at least one flight, possibly 2, while dressed in black. It wasn't always there, as they seemed to swap out canopies all the time. Pick up (or borrow) a copy of Supersonic: History of the X-15. I don't know if libraries would stock a book like this, but it's definitely worth checking out. The biggest problem is that the 15 was reconfigured for almost every flight, so you never know what's correct. Personally, I like the int. orange/white tank color. If the Special Hobby kit had come with them, that's the color I'd have gone with. But then again, I would have liked the option to add the scramjet or even the parking dolly .In your pic, what's that assembly above the external tank (to the right of the pilot)? I don't recognize the structure. And having built the one I did, I'm surprised, because, thanks to all the tech diagrams I've scoured over, I can almost build a working, full scale X-15, now .-Fred |
#164 |
The silver thing is the dolly w/o wheels. While I haven't decided for sure yet, I'm leaning toward building this this as flying condition (so landing gear up, no dolly), but I figured I'd paint up the parts and put them together anyways as practice.
I have a 1/72 X-1 Cutaway at home (that I've been wanting to do forever, but do it well). Its cast in orange too, but only the fuse (and then there is a second set in clear for the cutaway), the rest of the pieces are in gray. |
#165 |
One thing you can do for the X-15A-2 if you want to represent it with two cockpit windows is to grind open the window on the eyelet part and then use some Micro Krystal Klear to make a new window. It is a white glue type mixture that you can use to stretch over the opening like a soap bubble. When it dries, it looks like a nice plastic window. In fact, use it over the normal window opening and it probably will look better then the thick plastic part.
#166 | ||
Quote:
So that 1/72 cutaway is a commercially available kit, then? I saw a build up of one on another site and thought it was a custom job. I was all impressed with the engine detail and the ability to vacform a clear side. Guess I shouldn't be all that impressed ![]() Quote:
Does that Krystal stuff really work? I've read of hit and miss experiences. Some people love it and some people can't get it to work at all. How large of an opening can it be used on? Another option is to use a piece of plastic, like the bubble from an action figure. Dip it in Future to improve the clarity and then trim it to size. Should work quite well. -Fred |
#167 |
I think my Cutaway is a Tamiya kit. Got it at Smithsonian when I went there in 8th grade, so I dunno how available they are now.
Vaccing in clear isn't that hard though, provided you have a good mold. |
#168 |
It works, I've used it. Admittedly it tends to work best on smaller windows, but I've been able to get it to work on a window almost 1/4" long with a couple tries.
As for the Tamiya X-1, I think they are discontinued now, but they were available up until about 18 months ago. The current versions are just molded in gray plastic with the clear side though, not orange. Hobbycraft Canada also copied the kit and issued it themselves, albeit without the clear side piece. |
#169 |
A few days later than promised, but here it is, nonetheless
![]() I've added wiring to the backside of the IP, made new seatbelts from masking tape and masked the canopy. I wish there were still readily available masks for this kit. But, it is 23 years old, so I guess I shouldn't expect too much. -Fred |
#170 |
Ouch that looks painful! I'm definitely going with one direction first, then the other! And did I answer? Yes - I believe the frame is raised on the 1:18.
I have not done wiring behind the IP, but it looks great. I may have to add that! |
#171 |
Well, the decals were so old that they shattered. I've got no other resources since the only AM company that made decals went out of business and nobody has any NOS. Nothing on ebay, either.
If anyone has any suggestions, I'm all ears. -Fred |
#172 |
Fred,
I have one of these, can scan the decals so you can reprint them if you want. Jock |
#173 |
That would be great, Jock.
If you could scan them at the highest res your scanner can handle, that would be greatly appreciated. I'll PM you with my email address. Now, I just need to find where to get white decal paper. Thanks, Fred |
#174 |
Shoot, I have white decal paper... but I wont be able to get to it 'till im home, otherwise I'd send you a sheet.
#175 |
I'll scan the 1/32 as well as the 1/18. Looks like the 1/32 is 4 gigs at 9600 res. I can send unlimited, can you accept unlimited size emails?
