And I thought I was busy. Beautiful clean work!
Steve
Steve
WARP NACELL UPDATE FOR - 06/11/11
It's been a crazy month for the Reliant and Enterprise. The Nacells are quite a job to get just right. The problem is with the seams on the top and bottom of the nacell. They do not join together in a nice straight and even seam unlike an injection molded kit. I've had to do a lot of sanding on almost all of the engine pieces. Remember that there are 8 engines total for 4 models, so it's a lot of work. I've only been able to opaque 3 of the engines so far and am still working on the final sanding for the other 5 engines. I do have 4 pics in the Enterprise Album, #'s 129-132 and 3 new pics in Reliant #'s 34-36.
As I've stated in my last updates, there is a problem with the grills on all of the models. The filming miniature has 5 lines of lighting effects on the warp grills whereas the DeBoers only has 4. The Polar Lights model has 5 grooves rather than 4. To me this is a huge mistake that would take a monumental amount of work to fix the problem so I'll just have to allow for the difference. Also, the pictures I have of the Warp grills show that the lighting effect only goes back so far on the engines and not all the way to the end of the grills. There is a little bit of difference in opinion as to which part of the grill actually lights up. I'm sticking with the deep grooves since it matches up with the movies stills I have. It's too bad this error is so obvious, at least to me. But what can I do. It will still look sharp when they are finished.
By my next update I should have the base colors started on the engines. See you then!
Mark.
Warp Nacell Update for 07/31/11
I Apologize for not posting anything for a while, but let me assure I have been extremely busy on these ships. As of now I am working on the most difficult part of building these models and that's the starting of the AZTEC Pattern for the Engines. In the DEBOERS ENTERPRISE update I've sprayed the basecoating of FLAT WHITE on all of the endines and pylons, then I began with the first of up to 5 different colors I will be using for the AZTEC patterns. I have also started on the basic "Lightning bolt pattern" for the support pylons as well as the masking off of the first color that will be needed for the complicated shading of the engines and so forth. It takes about 3 hours per engine just to start this pattern off. To date I've completed the masking of all of the Port Side engines on the Enterprise models. Now I will be doing the reverse pattern on all of the starboard engines. I had a tough time deciding on what exact pattern would be for the pylons because even though there are many great pics of the filming miniature's details around many different parts of the ship, there are very few clear ones of the support pylons. So I had to scour the movies again, finally finding a good or at least a half way decent shot while the Enterprise is in Drydock. (Thank gooness for ST:TMP) The shot is about 3-4 seconds long but it showed enough of what I needed to get started. There are 5 new pics in this album #'s 133-138.
Mark
Interesting, can't wait to see how this proceeds. NemVia, check out the Refit we've been putting together. I'm posting new updates today.
http://www.therpf.com/f11/1-2-studio...rprise-119657/
Just checked it out when I got home! Very saweet! Maybe you can do a Reliant as well!
Mark
Thanks..... I don't think that's going to happen. Waaaaaay to much on my plate and I really don't want to get into another five year project trying to shake out accurate references and spend all of that time working on one ship. Besides, my associate is actively working on something else. Sounds like a good idea, but I'm just not up to it. I'll leave that to someone else.![]()
Well, this month has sure been a productive one! I've spent the last 30 days or more doing nothing but masking and painting the Aztec patterns on the Warp Nacells and support pylons of the (3) Enterprise models. I've put 4 different colors on each of the engines so there were three different maskings that needed to be done. After all four colors were finished I had to removethe masks which takes about an hour and a half per side. There are 6 of these engines, so I will be doing this a little at a time over the next week or so. I will need to do some minor touch-ups to these engines, fix a few cracks and chips in the seams and paint, then I can finish all the flush vents, intakes, control thrusters and other parts that need detailing and paint. I will also be adding some small domes for the strobes on the top rears of the engines. Then I can add the decals that go on the back ends of the nacells. All around, the paint jobs are turnng out well. Please feel free to leave feedback and let me know what you think!
After the engines are finished I will begin work on the engineering hulls which I think will be a lot easier than the engines and there are only 3 that I need to finish rather than 6. See you next update!
Mark
[COLOR=#999999]http://www.NemVia.com[/COLOR]
In this update, I've added 15 new pics to the Enterprise album. It took about 2 weeks to mask off all of the engines for the detailing work. I've added 3 new colors as you will see, plus I did touch-up work on the warp nacell grills. I think the pics turned put good. Next I'll have to paint the front nacell grills copper, the inside stripe on the pylons will have 2 more shades of gray added to finish off that detail. There is some putty work that needs to be done on the basses of the pylons then I will put a very thinned out off-white color over the Aztec pattern to tone it down just slightly. It will look sharp when it's finished. Then I can add the decals to the rear of the engines. I've made my home page so that you can access the DeBoers Enterprise project from the side bar on the left. The new pics are on page 3 pics 149-163. Let me know what you think!
Mark
[COLOR=#22229c]Home - NemVia Productions[/COLOR]
Very good pictures. I like them very well. I looked them through and seen a few other interesting pictures. Good skill you have.
Quite possibly the best Star trek build I have ever seen!![]()
And Thanks guys! That means an awful lot! Helps me keep moving forward!
OKAY EVERYONE!!!!! Big update this month! I have added 16 new pics to the Enterprise (16 Pics) album! A lot of energy and work have gone into these engines and I'm happy to say that other than a few pieces that will be added later on, the Engines are all basically done!
In the Enterprise update, I've had to spray the entire engines with a very light and thinned out coat of off white. This will tone down the Aztec colors just a little bit but will allow the sublte shapes of the Aztecing to show through. I've also painted up all of the misc. details such as the inside stripes that run up the support pylons. This took 3 different colors to make the stripe look perfect, Then I've added the decals which in this case are only 2 decals to the rear of the engines. The only thing I need to add to these now are the small domes for the warp crystals and the strobes on the rear ends of engines. So now I can finally put these in mothballs for a while and start working on the next part of this project, which I'm looking forward to, and that will be the "Engineering Hull". At least in this case there are only 3 pieces to work on, so the updates might be a little closer together.The new pics are on page 3 of the Enterprise album pics 164 - 179.
See you next update!!!!
Mark
This picture pretty much settles it for me, I'm definatley going to keep the forward grill as a separate part to make it easier to paint on the 1/2 Studio Scale Refit. I'm going to have to get some build photos up, but I want to make sure that all things are done in sequence and in good time, so that nothing looks rushed.
Well, everyone! This has been a busy year for me. The projects are coming along nicely and I feel I'm gaining some momentem. Unfortunately because of my peak season which will be starting sometime this week, I'm afraid I won't have much time or energy or the will to do much on these projects for the next two weeks or so. However, I've been able to get a lot of things accomplished since the last update. Noteably:
In the Enterprise build: I've added 26 new pics starting on page 3 slide 180 thru page 4 slide 205. I've begun working on the engineering hull. Like the warp engines there is a ton of putty and sanding work that needs to be done and redone. The bottoms of the hulls are the worst parts. They have a little bit of a valley in them which makes it very difficult for a nice smooth and rounded finish. I've had to fill in the old mounting holes on the 2 shipd that will be mounted from the saucer section in the drydocks and the other ship needed a larger bore hole for the mounting rod that will be used for the Mutara Nebula diorama. I have also added some new nacell mounting holes for when the engines are finally attached to the hull. I'm also going to add the lighting effects that are seen on wither side of the travel pod docking ports. To do this I had to drill out the old hatch doors and have rebuilt my own doors so that I can re-cast them in clear resin to allow for the small but interesting lighting effect.
Recasting a LOT of parts. This model was not inteded for lighting that is for sure. That is why all of the port holes need to be drilled out. But also, there are other pieces that need to be redone. So far I've recast the torpedo launching tubes, the lighting housing for underneath the fantail, the strobe light covers or domes for the flashing light effects, the airlock piece which I built at the begining of this project and have now finally got around to casting it into a single piece. I only need two of these pieces, that's why it took so long to get to. And finally the largest piece I've had to cast: the main deflector dish and the dish housing. This too was originally to be done as two seperate pieces, but I didn't like the way the hole drilling was turning out and I do not want it to look like a drilled them out either. So I recast these two pieces into one clear resin piece. I will then follow a technique that was used while building the Spacedock in STIII:TSFS where the entire plexiglass model was first painted over and then all of the spots that were supposed to be windows or portholes where lightly scratched off to allow the interior lighting to come through. I tried this on a scrap piece and it works out beautifully. I will have pics of this later on.
I just have a few more small things to add onto the engineering hull by way of detailing and then I will be ready to begin the painting which I am looking forward to doing.
Well, that's it for this update. Please be safe everyone. I will see you in 2012!
Take care, Mark
As mentioned in my last update I have updated some of the features on my site to help make it easier for Members and Visitors to find my latest updates without having to search though too many photos. Starting this month, you will be able to go directly to the current updates by clicking on the UPDATES FOR JANUARY 2012 page on the left hand sidebar. I will probably leave 2 or 3 months worth on the homepage and then move them to the appropriate pages later on.
Also thanks to everyone who has visited my site. Last month My 100th member joined in. Don't be afraid to join up! More are always welcome!
Now for my first update this year, I've been doing some refining of the details on the secondary hull. I've added all of the re castings of the Travel Pod Doors and epoxied them in place, next the will be prepaired for opaqueing and painting. I've also started working on how to put the lenses on some of the lighting effects. In this case it will be the Lighting ouside the Hanger bay. My solution was to drill the holes out, then add clear resin into the cavities. Not a very easy process, but after the work is done it looks pretty sharp. I've taken a couple of pics to show what the lighting effects will turn out like in the secondary hull. The same goes true for the Thrusters. I've decided to cut out the wedges on the tops and bottoms of the saucers and re-insert them with clear epoxy resin pieces. Right now I'm still making the molds for these parts and I should have the first of them done in a few weeks. In the meantime, I've also been casting several clear and white resin shuttle craft that I will be using for the hangers and also the Drydock model for when I start on that project. So stay tuned. I will be opaquing the secondary hull in the up-coming weeks and then I can start on the Aztecing for the Secondary Hull.
See you next month.
Mark
NemVia
Deckhand
Posts: 12 Joined: Mon Sep 12, 2011 4:08 pm
I have 16 new pics in the February update. I have spent a lot of the last month trying to smooth out the Engineering Hull. Ive been re-shaping a lot of the viewports and adding places for new lighting effects both to the Travel Pod Air-lock doors as well as the Hanger Deck. All of this is done in preparation for the Aztec patterns that will soon be added. To help protect some of the etched lines in the hull as welll as add some detailing I have begum masking out all of these lines and details. This process takes about 2-1/2 hrs per side. The pics in this months update show all of the detailed masking. I will then begin adding different shapes to different parts of the hull to begin some of the Aztec work.
Other updates this month include the spraying of the Main Deflector dish and housing piece which will also have some Aztecing put into it. Also I've sprayed the Bridge pieces in preparation for their detailing work. By the next update I hope to have at last 2 more color shades added to these pieces. See you in next months update.
Mark
Hey Mark,
I came across your web site a couple weeks ago doing some research for my own Big "E" build and the only thing I could say for hours was a jaw-on-the-floor "Wow".
amazingly well done.
Jason
Thanks Jason! Glad you like the projects!
Update for March 2012 - 17 new pics!
Greetings everyone! Well, it's now March. Time is flying by quickly! This past month I've been working on the masking for the 4 different shades of Aztec paneling for the entire Engineering Hull. So far I've been able to do the first 3 shades and 2 seperate masks. I was able to spray the 3rd shade on this morning. After the paint has set for 24 hrs I can begin the masking for the final shade on the hull and do some minor masking for the Strongback features as well as the housing for the main deflector dish and the dorsals front and back. On a few parts of the hull, some of the small masks have come off or have moved a bit due to the handling and from what I'm seeing the painting is turning out very well. Unfortunately we won't get to see what it all culminates to until the final colors have been added, the paneling is toned down and then the masking can all be removed. I've also begun some more masking for the main deflector dish piece (that is not connected to the engineering hull). The Deflector housing and stronback will be done in slightly darker colors, but they will not stand out too much. I'm really trying to shoot for the look in ST:TMP where everything is more subtle. From WOK onward there have been different and duller finishes added to the miniature for filming purposes. After the painting is all finished for the Engineering Hull I can finally add the Nacells to the hull and start working on some of the wiring and lighting. I feel real good about how things are looking so far and even I am looking forward to my own future updates. It's getting there my fellow modelers. Just hang in there! To view the pics go to my site below!
See you next update,
Mark
This has been an extremely busy month. All of my work has centered on the Secondary Hull and the Strongback detailing. There are 4 different colors added to the Aztec pattern on the engineering section and then they were oversprayed with the final off-white color that will be the ships signature look. The Strong back was a little different though. I used about 6 shades on this part as well as the deflector dish housing. Although the final colors are not on these parts, the Secondary hull is now completely Aztec-ed. There are 26 new pics in the Updates For April page. I mounted the engines on the hull as well as the saucer to get an idea of how everything will look together. Check out the pics and let me know what you think. I will be finishing up the Strong back as well as the front part of the Deflector dish for next month's update. I will start assembling the Hanger deck, the botany Deck and some of the wiring for the engines. I will also finally begin to work on the Saucer section. So stay tuned and I will see you next month!
Mark
Looks like you got a fleet of them going
But very impressive build
Thank you for sharing. Seeing builds like this being done is really an inspiration to all us normal folk without superhero powers.
Reading your blog, you mentioned that part of the renovation work you did was fixing rods on the Drydock that were bent over time. Was there a reason for not using some other type of material like Aluminum? on a small scale it shouldn't make a difference in weight, however, on this scale perhaps so.
keep up the excellent work.
Jason
At the time I built the first drydock, I wanted to build it just to build it. I did want to make the framework as light as possible and at that time the stock rods were the best bet. At first I had no intention of selling the model so I was going to keep it at my house. But things changed. So, when the model was moved around, things rattled and loosened up a bit. As I was tightening up some of the frames to make them lign up a lot better, some of the plastic rods were warped out of position, some popped out and some of them were lost forever. I never intended for the model to get sold when I built it. When I sold it though, the buyer asked me to do some repair work on things he wanted redone. The rods were one of the big problems. They were easy to fix, but there were a lot of them to redo. So sometimes when you cut corners, you have to pay for it in the long run. The PLE drydock was 42" in length. The ones for the DeBoers are going to be well over 50". There will be a lot more room to work around these things so I wil be able to use stronger materials on the new builds. That and the fact that my clients are paying for better materials to be used will make for a better and longer lasting display model.
Mark
