the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > MODELS > General Modeling
Can I apply fiberglass & resin directly to an oil clay sculpture?
Discussion on Can I apply fiberglass & resin directly to an oil clay sculpture? within the General Modeling forum, part of the MODELS category; I'd like to start building masks, but I'm unsure of
Reply
LinkBack Thread Tools
Old 01-08-2011, 11:09 AM   #1
Hoverboots's Avatar
Hoverboots has not been awarded enough reputation to matter.
I'd like to start building masks, but I'm unsure of where to start. I've completed a rough sculpt of Phantom Ganon from The Legend of Zelda: Ocarina of Time, and that's about as far as I've gotten. I work in a costume shop, and I ordered some extra firm oil clay from Kryolan. Are there any other sculpting mediums you would recommend?
Also, I intend to use these masks for playing airsoft in, as I am an avid airsofter. Is fiberglass the best way to go? I picked it for its durability, and have never really worked with it extensively before.
Another question, what would be the best thing to use to cover the eyeholes? My current airsoft mask uses a sheet of metal with holes punched in it, not really mesh, but with holes just small enough so 6mm bbs won't get in. I've seen others with clear plastic lenses, but they tend to fog up, and I have no idea how to shape them, or what they're even made out of.
I've seen some amazing work on here, and I'd greatly appreciate any input you can give me.
Last edited by Hoverboots; 01-08-2011 at 11:18 AM. Reason: sorry, pics were WAY too big at first
Hoverboots is offline   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 01-08-2011, 11:14 AM   #2
steveo's Avatar
steveo has a reputation level greater than 10!
Re: Can I apply fiberglass & resin directly to an oil clay sculpture?
I'm not sure if it can be done, but you won't get the detail you've sculpted since you'd be layering the FG on top.
steveo is offline   Reply With Quote
Old 01-08-2011, 11:20 AM   #3
Hoverboots's Avatar
Quote:
Yeah, I figured as much about the detail. What route should i take in order to get that detail and still retain durability?
Old 01-08-2011, 11:51 AM   #4
Contec's Avatar
Contec has a reputation level greater than 200!Contec has a reputation level greater than 200!Contec has a reputation level greater than 200!
Quote:
You use plaster strips over your sculpt to make a negative mold of your mask. Then you use fiberglass inside that mold, thus making you have the same details and still being made from fiberglass.
Contec is online now   Reply With Quote
Old 01-08-2011, 12:12 PM   #5
Hoverboots's Avatar
Quote:
any kind of fiberglass you'd recommend using? I have the rough strips and the thick woven fabric.
Old 01-08-2011, 12:22 PM   #6
XtcofPain's Avatar
XtcofPain has a reputation level greater than 10!
Your Props
Hey man if your looking to make a hard fiberglass mask you will need some gelcoat and some normal resin. You can make some gelcoat yourself if you mix powder with the resin. You paint in the gelcoat first and when it starts getting tacky you then apply your normal resin backed with fiberglass matting or fibercore. Remember to use a good release agent or your fiberglass will stick to the plaster as well.
XtcofPain is offline   Reply With Quote
Old 01-08-2011, 12:49 PM   #7
Hoverboots's Avatar
Quote:
Are there any products you'd recommend? I'm like, total prop virgin over here.
Old 01-08-2011, 01:00 PM   #8
stapleton13's Avatar
stapleton13 has not been awarded enough reputation to matter.
You can brush several layers of liquid latex over your sculpt. This usually takes some time, because you have to let each layer dry before you apply another layer. Then put the plaster over the latex. After that is dry you can remove the plaster, and latex. Then place the latex back into the plaster. I have used fiberglass in latex several times. You can usually get a few good casts before the latex gets too bad to work with. It works good for large items that need detail, without the big price tag.
stapleton13 is offline   Reply With Quote
Old 01-08-2011, 01:24 PM   #9
Contec's Avatar
Here is a tutorial..YouTube - How to make a custom airsoft mask
Old 01-08-2011, 02:04 PM   #10
piehead has not been awarded enough reputation to matter.
the way i would do this and ive done them before is to make a silicone mould by brushing on a detail layer of silicone then a thickened couple of layers to get to about 10 mm thick. i would then back this with either a plaster or fibreglass jacket. a latex mould will shrink up to 10 percent and will not last for multiple fibreglass copies as the styrene in the resin will attack it. once the mould is made i would brush in a detail coat of gel coat to approx 2mm thick. when that turns rubbery laminate 2 layers of fibreglass matt and 1 layer of fibreglass tissue / surface coat. for the mesh lenses look at the mesh used to patch holes in car bodywork from the auto store. that should do you. a good general moulding silicone would be platsil spray 25 or 70/25 from polytek or do a google for brick in the yard in the states or mouldlife in the uk. has a good cure time and both excellent for this type of work.
piehead is offline   Reply With Quote
Old 01-08-2011, 02:06 PM   #11
by the way for a great sculpting medium check out the chavant range of oil based clays. pretty much industry standard.
Old 01-08-2011, 02:27 PM   #12
steveo's Avatar
also get yourself a good air ventilation mask before you start using fiberglass. That stuff is toxic.
Old 01-08-2011, 03:02 PM   #13
clonesix's Avatar
clonesix has a reputation level greater than 10!
Nice sculpt. It looks like water clay to me. Water and (polyester) resin DO NOT mix well!
If I understand the problem correctly, you want to reproduce this mask in fiberglass for use as a paintball mask?
As mentioned above, you must make a negative mold of the sculpt first, and then laminate fibergall into it. Depending on how many masks you want to make, will determine the type of mold that you need to make.
You can make a plaster mold of the sculpt, but only get one mask out of it, and the sculpt will be destroyed.
you can make a (more expensive) silicone mold, and produce several fiberglass copies, and the sculpt will be destroyed.
Making the fiberglass mask is another can-o-worms, as you really don't want a smelly bag of needles strapped to your face. (for safety concerns)
you tube has several videos on molding and fiberglass. it is a great place to start.
the materials are not cheap, expect this to cost $30 - $100
clonesix is offline   Reply With Quote
Old 01-08-2011, 03:36 PM   #14
smelly bag of needles.... yup you are correct but thats what the fibreglass tissue is for it works as a surface coat that gives a nice smooth finish. also let the fibreglass sit for a week before wearing this gives all the excess styrene time of release. an easier less smelly alternative would be to use fast cast in the mould. again paint a detail layer in then add thickened fast cast. i like polyfibre to thicken. you can just butter that in then before it finaly cures just use a brush and a bit of acetone to smoth the inside. easyflo 120 is great for that. cures very fast, low odour and strong.
Old 01-08-2011, 08:01 PM   #15
bwayne64 has not been awarded enough reputation to matter.
I would personally make the negative mold with either epoxy glass, or polyester glass. Then make the copies from epoxy glass. Less fumes to worry about after curing. I'd make the mold about 1/4 to 3/8 an inch thick, if you plan to pull a lot of masks. Polyester molds are much cheaper than epoxy, so I'd use that for the mold. You could also vac form the masks with ABS plastic. But you'd probably have to build the teeth separately, if you want to retain the detail there. Great sculpt by the way, Cheers,
Joe
bwayne64 is offline   Reply With Quote
Old 01-08-2011, 08:56 PM   #16
clonesix's Avatar
From what I can see, there are too many undercuts to make a hard tool. (fiberglass mold) If you want to pull a fiberglass part, You will need a soft tool (rubber matrix mold)
Once again, it will depend on your budget, as silicone RTV is $100/gallon. You will need about a quart for something this size.
I agree with using epoxy resin over polyester. It is not as easy to use, as it is thicker, and also more expensive.
Old 01-09-2011, 12:26 AM   #17
Hoverboots's Avatar
wow, you've all been a great help,... I'll post back with updates when I can! Thanks a million!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
working with oil based clay? takevin Replica Movie Props 8 02-01-2011 10:30 AM
Brush molding oil based clay spidermanc General Modeling 6 12-12-2010 03:32 PM
Casting straight from oil clay? DYSTORTEDINC General Modeling 7 10-06-2010 02:20 PM
Oil Based Clay GBrittelleJr Replica Movie Props 1 06-05-2009 03:59 PM
HELP: tips for working with oil based clay???? steveo General Modeling 3 05-20-2009 08:25 AM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
