1. Formerly cobalt crimson Wes R's Avatar
    Join Date
    Jan 2010
    Location
    Western PA
    Message Count
    8,301
    Jun 21, 2012 - Best way to add heat shield tiles to shuttle? #1
    I have an 80s Transformer who is a large Space Shuttle, a little over 10" long, and was trying to find an easy way to replicate either real heat shield tiles or something like them. I have pics of the real thing but i'm not sure how well they'd scale down let alone scribe them into the plastic. I had thought of a thin layer of sculpty with a shape of some sort but that seems a bit rough too. Anyone have ideas?
  2. RPF Premium Member jedimaster's Avatar
    Join Date
    Nov 2009
    Location
    Planet Perth
    Message Count
    2,681
    Jun 21, 2012 - Re: Best way to add heat shield tiles to shuttle? #2
    You can buy decals for the 1/72 kits. Sounds about the right size. Or you could mod them to fit.
  3. Shat happens robn1's Avatar
    Join Date
    Aug 2007
    Location
    Woodbridge, VA
    Message Count
    2,402
    Jun 21, 2012 - Re: Best way to add heat shield tiles to shuttle? #3
    10" is more like 1/144. Try painting the tiles. The old Famous Spaceships book showed this technique, using window screen as a mask to spray through. Paint the shuttle medium gray overall. Then mask and spray the bottom black tiles through the screen, then the upper white tiles.
  4. Zombie_61's Avatar
    Join Date
    Mar 2007
    Location
    Southern California
    Message Count
    2,620
    Jun 21, 2012 - Re: Best way to add heat shield tiles to shuttle? #4
    Robn1 is correct, yours is closer to 1/144 scale. At that scale you shouldn't be able to discern any pattern in the tiles because of the tight gap and "step" tolerances.
    If you're trying to replicate a "new" shuttle (i.e., one that wouldn't show the effects of re-entry), mask the area and paint it flat black. You're done.
    If you're trying to replicate a "used" shuttle, take a look at this photo. You'll notice the only discernable pattern is around the three landing gear doors and the two square umbilical hatches just forward of the body flap (that somewhat flat section under the main engines). The rest is a random selection of new tiles, semi-new tiles, and scorching. Unfortunately, none of the currently available 1/144 scale decals (and there are very few) replicate this accurately.
    When I get around to building my Revell 1/144 scale shuttle in the not-too-distant future (hopefully) I'm planning to mask and paint flat black as suggested above, drybrush using various shades of gray to replicate the scorching effects, then pick out the new and semi-new tiles by hand with a small brush. Time consuming, to be sure, but if you want it done right you have to do it yourself.
  5. Robiwon's Avatar
    Join Date
    Dec 2007
    Location
    Danville KY
    Message Count
    1,818
    Jun 22, 2012 - Re: Best way to add heat shield tiles to shuttle? #5
    If your just wanting to get the effect of tiles try this modified window screen method. Tape a section of window screen with a small enough mesh for your tiles to the bottom of the model. Using flat black spray paint spray the bottom in one direction going side to side. Example, hold the can at the back of the model and spray toward the front of the ship. Keep this angle until the bottom is covered. Do not spray directly "down" at he model, keep the can low at an angle. Once that is dry, take some gunmetal colored paint or dark grey, and hold the can at the nose, pointing toward the rear. Spray until you have the bottom covered. Do not change direction, always have the can pointing toward the rear at a low angle going side to side. This is a technique for doing a carbon fiber type paintjob. You will end up with squares that are black on one edge and grey on the other edge. This will give you an intersting tile effect for your Transformers shuttle.
  6. opal1970's Avatar
    Join Date
    Nov 2011
    Message Count
    162
    Jun 22, 2012 - Re: Best way to add heat shield tiles to shuttle? #6
    Robiwon said: View Post
    Sounds interesting, do you have any pics of this method on a finished build?
    Admitadly, without digging deeply, Google did not produce any information in this area.
  7. Robiwon's Avatar
    Join Date
    Dec 2007
    Location
    Danville KY
    Message Count
    1,818
    Jun 22, 2012 - Re: Best way to add heat shield tiles to shuttle? #7
    I looked online as well. All I could find was just spraying one color thru mesh. The tip I talking about was in an issue of Scale Auto Enthusiast. If I can not find it online I will take some pics of the process tonight when I get off work for you.
  8. Formerly cobalt crimson Wes R's Avatar
    Join Date
    Jan 2010
    Location
    Western PA
    Message Count
    8,301
    Jun 22, 2012 - Re: Best way to add heat shield tiles to shuttle? #8
    I need to tear him down and paint him, and do some reengineering, but i'll give the screen technique a try on some scraps to practice. Worse comes to worse I can always just paint the bottom flat black. With it being a Transformer i'm assuming his heat shields would be far different.
  9. opal1970's Avatar
    Join Date
    Nov 2011
    Message Count
    162
    Jun 23, 2012 - Re: Best way to add heat shield tiles to shuttle? #9
    Thank you very much.
  10. pengbuzz's Avatar
    Join Date
    Mar 2012
    Location
    That really squat, funny looking Viper
    Message Count
    189
    Jun 24, 2012 - Re: Best way to add heat shield tiles to shuttle? #10
    Wes R said: View Post
    Sky Lynx by any chance?
  11. Formerly cobalt crimson Wes R's Avatar
    Join Date
    Jan 2010
    Location
    Western PA
    Message Count
    8,301
    Jun 30, 2012 - Re: Best way to add heat shield tiles to shuttle? #11
    Sorry I haven't looked in here lately. Yep i'm totally reworking Skylynx from shuttle to lower half. I wanted to get some spare shuttle motors to rig something cooler like in Armageddon (got some inspiration from that shuttle) but man 1/72 shuttles are expensive.
  12. JMChladek's Avatar
    Join Date
    Nov 2009
    Location
    Bellevue, NE
    Message Count
    1,177
    Jul 1, 2012 - Re: Best way to add heat shield tiles to shuttle? #12
    Brand new 1/72 shuttle kits are expensive. But if you go to eBay and look for the older boxings of the Revell and Monogram kits (orbiter only, if you want a stack, expect to pay a lot) and you can find some very good bargains. The plastic in the older ones is exactly the same as the current ones.
Similar Threads
  1. Replies: 59
    Last Post: Aug 31, 2012, 10:08 AM
  2. ID4 floor tiles
    timeslip, Studio Scale Models
    Last Post: Jul 1, 2011, 4:20 PM
  3. Fabricating: Trench Gun heat shield
    Lutso, Replica Movie Props
    Last Post: Mar 2, 2011, 1:33 PM
  4. Now Finished Custom Shield of Gondor (Lurtz shield next!)
    SirJediKnightTim, Replica Movie Props
    Last Post: Aug 29, 2008, 1:39 PM
1 2 3 4 5 6 7 8 9 10 11
