the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > MODELS > General Modeling
another Stargate chevron wall light build update
Discussion on another Stargate chevron wall light build update within the General Modeling forum, part of the MODELS category; This is my first ever attempt at making anything so
Reply
LinkBack Thread Tools
Old 10-19-2011, 12:38 PM   #1
andy19422's Avatar
andy19422 has not been awarded enough reputation to matter.
This is my first ever attempt at making anything so please be gentle .
I am using a resin casting from a screen used chevron to base my measurements on and lots of pictures I found on Google. I am also using blueprints from TEE, thanks mate.
I will be making the back panel that the chevron fits onto out of 10mm fibreboard then using 4mm foam to build up the shapes. I can then use this to mount the chevron too and screw the whole lot to the wall. This will also seal in the light to the chevrons two parts.
The wings are made from 75mm foam then cut in halve. I used a string with a pen loop to get the radius right. These are the first set of wings but I will make another set when I know what the end thickness of the whole thing will be. The lines on them were done using a dremal freehand, but when I do the next set I will make some thin ply guides.
The centre piece of the chevron was made using 33x20 pine then foam glued on. I have still to finish it and then fill it but I don’t think it turned out too bad. The amber panel will be the same resin that I will use to remake the V part. Feel free to point out mistakes and offer some suggestions.
By andy19422 at 2011-10-18
andy19422 is online now   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 10-19-2011, 12:48 PM   #2
Alan Castillo's Avatar
Alan Castillo has a reputation level greater than 1,000!Alan Castillo has a reputation level greater than 1,000!Alan Castillo has a reputation level greater than 1,000!Alan Castillo has a reputation level greater than 1,000!Alan Castillo has a reputation level greater than 1,000!Alan Castillo has a reputation level greater than 1,000!Alan Castillo has a reputation level greater than 1,000!Alan Castillo has a reputation level greater than 1,000!Alan Castillo has a reputation level greater than 1,000!Alan Castillo has a reputation level greater than 1,000!
Your Props
Re: another Stargate chevron wall light build
Looking great !
Any plan to have it light up ?
Alan Castillo is offline   Reply With Quote
Old 10-19-2011, 01:36 PM   #3
andy19422's Avatar
Oh yes, defiantly going to light them. I have two spaces on the wall waiting. I would love to see how the lighting was setup in the screen used chevrons. I was thinking of using a few small bulbs like the ones you find in ovens to get an even glow but these may produce too much heat so I might have to use LED’s and try to defuse the light in some way.
Old 11-10-2011, 12:00 PM   #4
andy19422's Avatar
Hi guys, this is my first update, it has taken me a lot longer to get this far than I thought it would as I’ve made a few mistakes along the line. I tried to make the triangular parts from pink foam covered with filler but every time I sanded them I ended up damaging them, so after a week I gave up. I have now used 1.5 mm plastic. I cut the shapes from heavy paper first then when I was happy I drew round them on to the plastic. The larger shape is filled with expanding foam to give it a bit more strength. These were then coated in filler to give the paint something to stick to, then they were glued on and the gaps filled and sanded. I primed it today and noticed a few details that need work but I am happy how it turned out. I found some 4mm Perspex in the garage which I will try and fold with a heat gun for the centre piece.
By andy19422 at 2011-11-10
Old 04-12-2012, 01:59 PM   #5
andy19422's Avatar
While I am waiting for some parts for my Stargate Universe wall sconce run I decided to revisit my SG1 chevron build. The back board was made from 6mm MDF then the shapes were made from single and double layers of 1mm card and glued on. The board was molded and then cast in polyurethane fast cast resin from Tomps. The chevron was cast using a clear resin that cures to a pale amber colour but it changes the light shades so I will be trying water clear next time. I am going to try tracing or greaseproof paper to defuse the light a bit more. I was going to tint the chevron amber for SG1 or blue for the Atlantis gate but I am now using an LED strip that has thirteen colours so I can do either or some other colour to suit my mood. The centre V needs a bit more work to make me happy, I'm not sure if the shape below the lighted panel slopes back or is straight, it looks different in various photos. The wings will be made of pink foam with a layer of resin to strengthen then molded and slush cast. The best way of doing the lines I have found is by using a soldering iron, this seals the foam and makes a nice edge.
By andy19422 at 2012-04-12
Old 04-12-2012, 11:38 PM   #6
Commander Dan has not been awarded enough reputation to matter.
Re: another Stargate chevron wall light build update
VERY cool! That's looking great!
Commander Dan is offline   Reply With Quote
Old 04-13-2012, 02:07 AM   #7
andy19422's Avatar
Thanks. As the parts are only trial bits I have only put on a coat of Gray primer to see what they look like, the next ones will be painted like the screen used ones.
Old 04-13-2012, 07:28 AM   #8
Fuzzual's Avatar
Fuzzual has a reputation level greater than 50!
Your Props
Looks great!
Fuzzual is offline   Reply With Quote
Old 04-13-2012, 08:19 AM   #9
Rodewaryer's Avatar
Rodewaryer has not been awarded enough reputation to matter.
Nice work, you do yourself credit. Looking forward to how this appears in final form...
Rodewaryer is offline   Reply With Quote
Old 04-13-2012, 04:35 PM   #10
Roystar's Avatar
Roystar has not been awarded enough reputation to matter.
I went ahead and took a screencap from the opening in season 2 of SG-1 where they got some great shots of the gate in close up.
As you can see they do slope a bit at the tip of the chevron marker.
Keep up the awesome work!
Roystar is offline   Reply With Quote
Old 04-14-2012, 02:44 AM   #11
andy19422's Avatar
Thanks for the great pic. I realised after I made the first foam wings that there is a slope to match the inner V. Hopefully I will start on a new set this weekend. The part I need a good pic of is this
By andy19422 at 2012-04-14
Old 04-14-2012, 04:47 AM   #12
Roystar's Avatar
This is the best picture that I could get from the intro of season 2 that's taken from a top angle. It showa the top shevron marker since it moves during the intro and I guess that all the other are the fixed ones.
I'm re-watching SG-1 and Atlantis, one episode a day, so if I stumble over a better close up of the gate I'll be happy to upload the screencaps for you.
Edit: I also took a shot for you too see that the side lights on the markers differ when they are all lit. Not all of the "slits" are lighted on all of the markers. But there is one that is fully lit, far left.
And as a bonus I'll give you a top view of a non-moving marker.
Old 04-14-2012, 07:42 AM   #13
CJ 617's Avatar
CJ 617 has not been awarded enough reputation to matter.
Fantastic work....looks great!!
CJ 617 is offline   Reply With Quote
Old 04-14-2012, 01:29 PM   #14
cheech9898 has not been awarded enough reputation to matter.
Atlantis Stargate segment pictures by cheech9898 - Photobucket
cheech9898 is offline   Reply With Quote
Old 04-14-2012, 01:35 PM   #15
On the atlanits gates, everything is basically the same except they pushed the front of the gate out another 2 inches or so to accomodate the double set of vortex stabalizers in the inner ring area, extended the chevron outer wings by the same in depth and more less just forced the new slope angle of the panels. then flush mounted the constelation penels instead of recessing them like the regular milky way gate's moving inner ring. It looks wonky up close like these picks are but standing back like most camera shots are of the Atlantis gate it all looks normal.
Old 04-14-2012, 01:42 PM   #16
andy19422's Avatar
Thanks for the photos and the info Cheech, love your gate section
Old 04-14-2012, 06:19 PM   #17
Scouse Trooper has not been awarded enough reputation to matter.
Superb work there, great start, when will the rest of the ring be built
Scouse Trooper is offline   Reply With Quote
Old 04-15-2012, 12:42 AM   #18
andy19422's Avatar
If I had managed to buy a Stargate section from Propworx I would have molded it by now and had halve a gate in my living room
Old 04-15-2012, 03:50 AM   #19
andy19422's Avatar
I managed to cut out the new pair of wings yesterday and gave them four coats of resin. This morning I sanded down the high spots and have started with the filler. I've realised the lines are way to wide so I will fill them and then re-cut them with a dremal.
By andy19422 at 2012-04-15
Old 04-16-2012, 11:19 AM   #20
andy19422's Avatar
I re-cut the lines and put on a primer coat to see the parts that need work, I should have them finished in a couple of days. I am drawing the plans for remaking the centre V after I received some great photos, thanks guys. I made this for myself but as I am making the molds for all the parts would there be any interest in a run? The chevron is 53"x19"x3"
By andy19422 at 2012-04-16
Old 04-18-2012, 12:33 PM   #21
andy19422's Avatar
I am having a lot of trouble with the wings The problem is they are very thin and every time I fill and sand I put another dent in them. I think I'll have to mould them, then work on the solid resin ones and then remould again.
Old 04-18-2012, 03:28 PM   #22
markkNL has not been awarded enough reputation to matter.
This is really awesome, if you have any templates of this, I would love to see them. Might even think of making my own. Keep up the good work.
markkNL is offline   Reply With Quote
Old 04-21-2012, 04:59 AM   #23
Roystar's Avatar
It's taking on a whole new shape now that you put the orange piece in place, kinda makes it look almost finished.
Old 04-27-2012, 01:18 AM   #24
Your Props
Quote:
Originally Posted by andy19422 View Post
... I made this for myself but as I am making the molds for all the parts would there be any interest in a run? ...
Personally, I'd be all over this, but it would depend on the price, finish, and how it could ship vis-a-vis the shipping cost.
What have you got to loose ? Start an interest thread in the JY eventually
Old 04-27-2012, 02:12 AM   #25
andy19422's Avatar
Hi Alan, an interest thread is still a way of yet. I am waiting for some cash to come in for my SGU wall sconce lights so I can afford more supplies. I should be picking the ply back plates up today from the CNC company for the wall lights. I was promised they would be done in 2-3 weeks but it has taken six
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stargate Chevron Light Prop - Build jessec General Modeling 29 11-23-2011 04:31 AM
Stargate Chevron light/sconce FuseNova Replica Movie Props 15 09-12-2011 11:35 PM
Stargate Chevron WallLight´s The Collector Replica Movie Props 0 09-05-2011 07:54 AM
SG Chevron Wall Sconce Build Thread Draphin Replica Movie Props 25 09-02-2011 08:45 AM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
