After a bit of a wrestling match with some massive resin parts, I have completed the thruster module. This is a removable assembly containing all the engine openings for the ship. It is removable to make the job of detailing the inside of the openings much easier. Some details are already molded into the castings.
What makes this a challenge? First, the thruster openings are cast resin. As a result, they tend to shrink and warp (typical for resin parts). The tolerances on this build are very tight (about 15 thousandths of an inch or 015). Not having had these castings in my hands until now, I had no way of knowing how well they would fit. As it turned out, they were off maybe 1/16. Not too bad. In addition, the warping/twisting caused a misalignment of about 1/8 inch on top of that.
Now that I am aware of this, I probably should have added more clearance to my laser-cut parts. As it is, they were very tight and so I had to do some hand cutting and machining to allow room for a proper fit. That took quite a bit of time.
Next, the thrusters are split into parts to allow you to get at the inside surfaces to glue in the details. In order to test fit everything and correct any warpage, they needed to be glued together. But, permanently assembling them would negate the advantage of having them split into sections for detailing.
The solution was to tack them together with CA and then heat and coax the parts into alignment. I then did some minor machining of the resin parts to achieve a near perfect fit. The finished assembly looks more like something made in a factory than anything I might have built by hand. So, there is a bit of a "cool" factor for me when I look at the final results.
BTW, I don't like to rely on glue when joining dissimilar materials. It's fine when gluing acrylic or styrene to itself as those materials achieve a molecular bond when using the proper solvent. This creates a very strong joint that will stand up to stress.
When bonding dissimilar materials, however, you need to take things into account like expansion and contraction that can cause a glue joint to fail over time. While I could have used CA to glue the resin parts to the acrylic structure, that would've resulted in a brittle joint that could snap if flexed. Just getting all this to go together required quite a bit of handling and I would have been popping glue joints right and left (I already ran into this problem because I tacked the thruster castings together).
I solved this issue by using screws to secure the thruster castings to the structure. No glue was required at all. The castings were specifically designed for this by way of screw bosses and pilot holes that line up with matching holes in the acrylic structure. All I had to do was drill out the pilot holes and install self-tapping #4 screws.
This module is still not completely finished, but this is about as far as I can go for now since the client will need to disassemble everything in order to detail each opening. But, I can still install the diffusers and honeycomb mesh. My design allows light to shine through while also permitting air to flow for ventilation. I'll tackle that next.
For now, I put the thruster module into the engine box just to see how it looks. The lower side boxes (now skinned) are loosely attached at this point. The front sloping section is also still under construction.
