Page 7 of 9 FirstFirst ... 23456789 LastLast
  1. xingshen's Avatar
    Join Date
    Jul 2010
    Location
    Jundland Wastes , Tatooine
    Message Count
    98
    Jan 20, 2011 - Re: Build Diary: Revisiting the Jedi Training Remote #151
    Either will work. You will need to scuff them up so your primer and paint stick.
    rockhopper said: View Post
    Do the Plastruct hemispheres need to be clear, or are the grey ones OK to use?
    Thanks
    RH
  2. Join Date
    Nov 2006
    Message Count
    36
    Jan 20, 2011 - Re: Build Diary: Revisiting the Jedi Training Remote #152
    Cool thanks
  3. theyrenotdolls's Avatar
    Join Date
    Jun 2006
    Location
    Cincinnati, OH
    Message Count
    86
    May 26, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #153
    So I've tried making the semicircles that go around the truck rims several times now but I just can't get them straight. Someone here mentioned that they made them from vacformed styrene hemispheres.
    Anyone have any vac formed hemi's ?
    Or any other tips?
    Thanks
    Den
  4. BrundelFly's Avatar
    Join Date
    Dec 2001
    Message Count
    2,894
    May 29, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #154
    Make the circle/donut. Measure the gap.
    Draw on the gap as to where you will cut it.
    Cut it but INSIDE were you should, so you leave some material.
    Bend them a little and glue on. THEN trim the gap parallel at the right separation.
    Make sense?
    It will work. Trust me.
  5. Formerly NightEyes
    Join Date
    Apr 2005
    Location
    NJ
    Message Count
    1,304
    May 29, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #155
    Yes, heed that advice. It does work, and so far no one has done vac'ed hemispheres.
    If you're having trouble visualizing the correct shape draw the circles on the hemisphere and trace the pattern onto some tape. Lay the tape flat on styrene cut bend and everything BrundelFly said.
  6. theyrenotdolls's Avatar
    Join Date
    Jun 2006
    Location
    Cincinnati, OH
    Message Count
    86
    May 30, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #156
    Thanks for the tips. Night eyes, already tried sketching it on the sphere and transferring over. Just couldn't get the hemi doughnuts cut out evenly or symmetric. I think I'll try brundlefly's suggestion next.
  7. theyrenotdolls's Avatar
    Join Date
    Jun 2006
    Location
    Cincinnati, OH
    Message Count
    86
    Jun 3, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #157
    Small update for me. So I've made my donuts. Here's how:
    Cropped this image from the tutorial, adjusted size appropriately and then printed
    Copied this template to styrene then cut out a donut. Then sanded and Checked size. It seemed to work.
    Then I copied this pattern to 9 more pieces of styrene.
    I then Realized the inside of the donut was the same size as this bottle of paint.
    So I used some sandpaper over the bottle in this fashion
    Then used all 10 donuts over the bottle to even out the outside perimeter
    Here's the result. Most are pretty even.
    Thoughts?
    I'll keep moving forward.
  8. darth_myeek's Avatar
    Join Date
    Dec 2007
    Message Count
    1,445
    Jun 5, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #158
    I have one of these olfa circle cutters. Not used it yet, but might be interesting.
  9. KrokoHunter's Avatar
    Join Date
    Mar 2004
    Location
    Denmark
    Message Count
    379
    Jun 5, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #159
    darth_myeek said: View Post
    I have one of those too .... as it is, I'm not to thrilled about it .. It keeps loosing alignment, so the radius either gets bigger or smaller ...... but I think a couple of glued on ABS strips would keep it aligned .. hmmm perhaps I should try that.. a lot of circular cuttings in a couple of upcoming projects
  10. theyrenotdolls's Avatar
    Join Date
    Jun 2006
    Location
    Cincinnati, OH
    Message Count
    86
    Jun 5, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #160
    Another quick question. So previously I glued on the uneven semi circles onto the hemispheres. Now that I've redone the donuts I need to remove the old ones. I used zap a gap, I think. Is there any good solvent to remove this? Or should I just start over w new hemispheres.
    Scraping it off w a razor blade isn't working well.
  11. KrokoHunter's Avatar
    Join Date
    Mar 2004
    Location
    Denmark
    Message Count
    379
    Jun 11, 2012 - #161
    KrokoHunter said: View Post
    Found out yesterday, that there are two versions of the Olfa cutter. A crappy one (the one that I have) and a great, more sturdy one, which I borrowed at a buildingsession yesterday. I Can totally recommend the sturdy one :-)
  12. KrokoHunter's Avatar
    Join Date
    Mar 2004
    Location
    Denmark
    Message Count
    379
    Jun 11, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #162
    I started my own Training Remote yesterday.... I've taken the vac-form approach as Frank recommended, for the styrene-details ..... I really can only recommend this approach, because it'll result in a super-snug fit of the styrene detail
    (A big thanks to Moe for help with the vac-forming)
    (And I promise, no more hijacking of Nighteyes' thread .... I promise to start my own thread, once I get a bit further with the project )
  13. Formerly NightEyes
    Join Date
    Apr 2005
    Location
    NJ
    Message Count
    1,304
    Jun 12, 2012 - Re: Build Diary: Revisiting the Jedi Training Remote #163
    You did it!
    Just check the dates a few pages back to see how long we've been talking about vac'ed hemis.
    Had my own remote at Wonderfest this year so some of you guys might have seen it.
  14. Moska's Avatar
    Join Date
    Jul 2010
    Location
    La Rioja, Spain
    Message Count
    138
    Jun 15, 2012 - Re: Revisiting the Training Remote #164
    Nighteyes said: View Post
    Thanks to Paul's tip I have cast nearly everything I need for the project. That Elmers worked like a charm! But before you get a peak at my duplicates why not take a moment to review those Tamiya parts like I promised.
    Hi Nighteyes.
    I'm sorry to bring now an issue that you mentioned four years ago, but I'm always trying to learn new techniques.
    What's Paul's Tip that you reference in that old post?
    Very good work with your Training Remote.
    Rafa
  15. Formerly NightEyes
    Join Date
    Apr 2005
    Location
    NJ
    Message Count
    1,304
    Jun 15, 2012 - Re: Revisiting the Training Remote #165
    Hey Rafa,
    When I made my molds from silicon it bonded with the double sided tape I had used to hold the parts in place. The tip was to brush on Elmer's white glue over the tape to prevent this from happening.
    I very lightly weathered my remote but I continue to work on matching the original spot for spot, so in my mind it is still unfinished.
  16. Moska's Avatar
    Join Date
    Jul 2010
    Location
    La Rioja, Spain
    Message Count
    138
    Jun 16, 2012 - Re: Revisiting the Training Remote #166
    Ok, I get it.
    And I find it very useful that advice because I also use double sided tape to attach the pieces to be molded.
    Many thanks.
    Rafa
  17. KrokoHunter's Avatar
    Join Date
    Mar 2004
    Location
    Denmark
    Message Count
    379
    Jun 17, 2012 - Re: Revisiting the Training Remote #167
    what measurements did you guys use for the inner and outer diameter of the rings? I used 23mm (inner) and 46mm (outer) as stated in Franks tutorial ..... I should have seen it right away, that these numbers doesn't add up, since the outer diameter of the rim is 23mm ... the the inner diameter of the styrenering should be closer to 30mm and the outer diameter should be somewhere between 46-52mm
    Oh well ... I need to make some new rings .. glad we made a couple of extra vac-pulls
  18. KrokoHunter's Avatar
    Join Date
    Mar 2004
    Location
    Denmark
    Message Count
    379
    Jun 17, 2012 - Re: Revisiting the Training Remote #168
    Did some new measurements, plus got some measurements from Franks rotocasting .... this gives me the following measurements
    Rim: 23mm
    Inner diameter: 32mm
    Outer diameter: 54mm
  19. Formerly NightEyes
    Join Date
    Apr 2005
    Location
    NJ
    Message Count
    1,304
    Jun 17, 2012 - Re: Revisiting the Training Remote #169
    I started with Franks measurements, referenced one of his rotocast kits, and finally eyeballed some adjustments. I am traveling at the moment but when I get back tomorrow I'll measure what I've got on mine. Fairly certain it's very close if not dead on.
  20. theyrenotdolls's Avatar
    Join Date
    Jun 2006
    Location
    Cincinnati, OH
    Message Count
    86
    Jun 17, 2012 - Re: Revisiting the Training Remote #170
    Rim: 23mm
    I have 55-56 mm outside diameter but I think after sanding clean it's closer to 54. Probably splitting hairs.
    How'd u cut ur semicircles.
  21. KrokoHunter's Avatar
    Join Date
    Mar 2004
    Location
    Denmark
    Message Count
    379
    Jun 19, 2012 - Re: Revisiting the Training Remote #171
    theyrenotdolls said: View Post
    I'll make you some Show'n'Tell pictures when I cut the new sets
  22. Formerly NightEyes
    Join Date
    Apr 2005
    Location
    NJ
    Message Count
    1,304
    Jun 20, 2012 - Re: Revisiting the Training Remote #172
    Mine are measuring about 56mm for the outside diameter. I recall the original being slightly irregular in regards to geometry and placement.
  23. KrokoHunter's Avatar
    Join Date
    Mar 2004
    Location
    Denmark
    Message Count
    379
    Jun 22, 2012 - Re: Revisiting the Training Remote #173
    Quick question .... how did you measure the ring.. and did you measure a mounted (curved ring) or a flat, cut ring?
    Because this will have a lot to say on the outer diameter (see pic) ... so is 56mm measured along the curved surface (#2) or measured in a straight line with e.g. a caliper (#1)
  24. KrokoHunter's Avatar
    Join Date
    Mar 2004
    Location
    Denmark
    Message Count
    379
    Jun 22, 2012 - Re: Revisiting the Training Remote #174
    I've just made some remeasuring... and I think the outer diameter on the curved ring, measured with a caliper (#1) should be roughly 53mm... this would compare pretty good to a 55-56mm ring cut from a flat piece of styrene and then bend'n'curved
  25. Formerly NightEyes
    Join Date
    Apr 2005
    Location
    NJ
    Message Count
    1,304
    Jun 22, 2012 - Re: Revisiting the Training Remote #175
    I measured with the curve by marking a piece of tape on the remote and then laying it flat. I still think its closer to 55.5 than 56.
Similar Threads
  1. Jedi Training Remote
    Luke0312, Replica Movie Props
    Last Post: Mar 23, 2013, 5:19 PM
  2. Training Remote
    joewhite, Replica Movie Props
    Last Post: Mar 24, 2012, 12:46 PM
  3. TRAINING REMOTE: Make your own.
    BrundelFly, Studio Scale Models
    Last Post: Jan 18, 2012, 1:35 AM
  4. Question about the training remote...
    Qui-Gonzalez, Replica Movie Props
    Last Post: Mar 19, 2008, 2:45 PM
  5. Almost truly hovering Training Remote
    Gigatron, Replica Movie Props
    Last Post: Dec 6, 2006, 12:07 PM
1 2 3 4 5 6 7 8 9 10 11
