the RPF   Replica Movie Props
Replica
Props
Screen Used Movie Props
Screen Used
Props
Movie Costumes
Replica
Costumes
Sculpture and Makeup
Sculpture
and Makeup
General Modeling
General
Modeling
Studio Scale Models
Studio Scale
Models
Movie Discussion
Movie
Discussion
Collaborate, create, and collect at the internet's largest community dedicated to props, costumes and models.    The Replica Prop Forum on Facebook   The Replica Prop Forum on Twitter   The Replica Prop Forum RSS Feed   The Replica Prop Forum on YouTube
Go Back   the RPF > MODELS > Studio Scale Models
Pyro X-Wing kit WIP
Discussion on Pyro X-Wing kit WIP within the Studio Scale Models forum, part of the MODELS category; wizardofthenorth, Sorry for the delay in my response.It is about
Reply
LinkBack Thread Tools
Old 12-19-2011, 11:06 PM   #51
kh39's Avatar
kh39 has not been awarded enough reputation to matter.
Re: Pyro X-Wing kit WIP
wizardofthenorth,
Sorry for the delay in my response.It is about 15mm.The trench of the R2 strip is about 25mm wide on the pyro kit.So if the original master was 25.4mm(1 inch),the pyro kit fuselage woud be 2% of shrinkage as the rear plate is 2% smaller than the donor part(Sherman).So if you don't want to use the rear plate of the kit Maybe it would be more than 15mm.Well,accually I'm still losing my way if I should use it or not
To degress a little.I've also measured the canopy a little bit.Since the canopy was too big.I cut in half and glued them back together to fit on the fuselage.I think it is 1% smaller than the pyro kit canoy.So in my opinion the hero X-wing is 1% smaller than the master.Pyro kit is 2% from the master which is awesome if I'm correct.
kh39 is offline   Reply With Quote
Ads ( Don't want to see advertising between posts? Register for free and become a member of our community! )
RPF Sponsors
RPF Recommends
Old 12-20-2011, 08:04 AM   #52
Formerly taitbb
wizardofthenorth has not been awarded enough reputation to matter.
I will be using the kit plate for sure. I am thinking to take the back wall back even farther based on your analysis, as the backplate is fairly thick. Then adjust the depth with a shim.
wizardofthenorth is offline   Reply With Quote
Old 12-20-2011, 08:31 AM   #53
kh39's Avatar
Yes,the rear plate is thick,but I wonder it is thicker than the original and what we see in the recess is back wall or not.
Old 12-20-2011, 09:48 AM   #54
Formerly taitbb
To my eye, the back plate definitely seems thicker to picks I have seen...at least on the casting I have. Although I haven't trimmed it down to see it's final fitting. I am still in scribing and cleaning up phase. And I am sooooper slow.
I would think that is the back wall, as from the pics I have seen, the back wall I think is part of the base molded fuselage.
Old 12-20-2011, 07:19 PM   #55
kh39's Avatar
Thanks for your advice.But the lower fuselage shouldn't have a back wall right?And thank you for the rear plate picture.It is a first time for me to see it.It is very interesting.
I'm working on the lower fuselage.I don't like scribing panel lines on resin.
Old 01-09-2012, 06:59 AM   #56
kh39's Avatar
I 've molded an armature cap.(I don't know what to call.)It doesn't look good,but
sitill okay to use.I also did the brick pattern sheet briefly.
The condistion wasn't good.The resin was almost cured,so I didn't have much time to do,but even that it's difficult to make the thickness equally.If you have one more mold on the back of the brick patten sheet,it will work better I think.
By the way,if you want a SS looking pilot in 1/72 scale,buy a takara X-wing!
Old 01-15-2012, 03:44 AM   #57
kh39's Avatar
These are the inside of the fuselage before and after.
Old 04-08-2012, 07:54 AM   #58
kh39's Avatar
Very small update.
I'm woriking on a moving wings device.I went to the shop and showed RED 5 picuture inside to a sales person and the sales person discoved the motors on RED 5 were geared motors.
The geared motors I've bought are very powerful.Though these are for 24V,I used a 12V power pack,but these are still powerfull.
What sales person tolded me was power is OK,but adjustment of gears would be dificult.
Anyway firstly,I need a 19mm inside diameter gear for the rod,but it's diffcult to find.
I'm asking the sales person if the gear is available. If 19mm inside diameter will not be available,please anyone let me know the shop where I can get the gear!
update 2
The motors have been changed.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pyro X-Wing build with scratched canopy... Colin Droidmilk Studio Scale Models 18 11-06-2011 02:38 AM
Red 4 ? Pyro X-Wing Build jedimaster Studio Scale Models 38 07-26-2011 10:05 AM
Pyro X-wing model quality? Dedalus5550 Studio Scale Models 27 05-11-2011 10:40 AM
By continuing past this page, and by your continued use of this site, you agree to be bound by and abide by our Terms of Use.
© 2012 Movie Prop Sites, LLC. All rights reserved.
Visit our other sites which focus on the Boba Fett Costume and the Predator Costume.
1 2 3 4 5 6 7 8
